This page provides information on supported features in V-Ray for Cinema 4D based on the rendering type and hardware architecture.
Feature | V-Ray | V-Ray GPU |
Cinema 4D Team Render |
V-Ray Proxy | ||
Displacement | ||
V-Ray Fur | ||
V-Ray Clipper | (without Mesh mode) |
V-Ray Lights | ||
Image-based lighting | ||
Light and shadow linking | ||
Cinema 4D Omni Light | PARTIAL | PARTIAL |
Cinema 4D Spot Light | PARTIAL | PARTIAL |
Cinema 4D Infinite Light | PARTIAL | PARTIAL |
Cinema 4D Area Light | PARTIAL | PARTIAL |
Cinema 4D IES Light | PARTIAL | PARTIAL |
Cinema 4D Sun Light | PARTIAL | PARTIAL |
Cinema 4D PBR Light | PARTIAL | PARTIAL |
Brute Force | ||
Light Cache | ||
Caustics | PARTIAL 1 |
Preset: Back to Beauty | ||
Atmospheric Effects | ||
Background | ||
Bump Normals | ||
Caustics | (Production mode) | |
Coat Specular | ||
Coat Filter | ||
Coat Glossiness | ||
Coat Reflection | ||
Coverage |
Cryptomatte |
| PARTIAL |
Denoiser | ||
Diffuse | ||
GI | ||
LightMix | ||
Light Select | ||
Lighting | ||
Material ID | ||
Material Select | ||
Matte Shadow | ||
Normals | ||
Object ID | ||
Object Select | ||
Raw GI | ||
Raw Light | ||
Raw Reflection | ||
Raw Refraction | ||
Raw Shadow | ||
Raw Total Light | ||
Reflect IOR | ||
Reflection | ||
Reflection Filter | ||
Reflection Glossiness | ||
Reflection Highlight Glossiness | ||
Refraction | ||
Refraction Filter | ||
Refraction glossiness | ||
Render ID | ||
SSS | ||
Sample Rate | ||
Self Illumination | ||
Shadow | ||
Specular | ||
Total Light | ||
Velocity | ||
Z Depth |
Al Surface | ||
Blend | ||
Car Paint 2 | ||
Light |
V-Ray Material |
Fast SSS2 | PARTIAL (without raytraced (solid) and raytraced (refractive)) | |
Hair Next | ||
Bump | ||
2 Sided | ||
Scanned |
Material Override |
Cinema 4D shaders marked as are supported by V-Ray via the Bake Cinema 4D Shaders option available in Render Settings > Overrides > Textures or via the VRayC4DBake texture.
1. The new Progressive Caustics method works only with the Progressive Image Sampler and on CPU.
