Refresh – Updates the listed lights if lights have been added or removed from the scene. Isolate – When enabled, isolates a single light for IPR. The isolated light is on in the scene, while all other lights are turned off. See the Example below. Enable – Enables the light in the scene. See the Example below. Color – Specifies a color for the light. Intensity – Specifies the intensity of the light. Invisible – When enabled, the shape of the light source is invisible in the rendered image. |
