Please make sure that your system fulfills these requirements before installing V-Ray. Note that V-Ray is only supported for 64-bit operating systems and 64-bit versions of SketchUp.
Processor | Intel 64, AMD64 or compatible processor with SSE4.2 support |
RAM | Minimum 8 GB RAM, recommended 16 GB RAM |
Hard Disk Space | minimum 2GB, recommended 12GB (includes additional downloadable content) |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported |
Operating System | Windows® 8.1, Windows 10. |
SketchUp | SketchUp 2017, 2018, 2019, 2020, 2021 |
GPU Support | Maxwell-, Pascal-, Volta-, Turing- and Ampere- based NVIDIA card(s) with latest video driver or at least version 411.31
V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities. |
Operating System | Apple® macOS 10.10.x or higher |
SketchUp | SketchUp 2017, 2018, 2019, 2020 and 2021 |
V-Ray GPU is not officially supported on macOS. It works only with C++/CPU devices. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s). |
For more information on hardware, see the Hardware Recommendations article.
Customer support is available only for V-Ray 5 and V-Ray Next (V-Ray 4). Earlier versions are no longer supported. |
