Initially, the Scatter subtab loads empty prompting you to select a geometry from the Revit model and add it to the list. Only the following family types can be selected as Scatter hosts: - Floor
- Wall
- Roof
- Ceiling
- Curtain System
- Curtain Panels
- Column
- Ramp
- Stair
- Toposurface
- Mass
The Add Scatter Hosts button adds the selected objects the the list. The button works in a two-way fashion. You can either: - select a geometry and click to add it;
- click the button, then select a geometry and then click the Finish button which appears in the lower part of the Revit ribbon.
To delete a scatter host from the list, select it and then press the Delete key from your keyboard. When a Revit family instance, which has been added to the list, is deleted from the project itself, it would also be removed from the list. The button allows for applying V-Ray Scatter created in the Asset Editor to the selected host family. The items to be scattered will only be visible at render time and only over the surface of the selected host. To remove the association between a Scatter and its host, use the Unassign V-Ray Scatter button. |
