This page provides information on supported features in V-Ray for Cinema 4D based on the rendering type and hardware architecture.
Rendering
FeatureV-RayV-Ray GPU
Cinema 4D Team Render(error)(error)
Geometry
V-Ray Proxy(tick)(tick)
V-Ray Scene 3(tick)(tick)
Displacement(tick)(tick)
V-Ray Fur(tick)(tick)
V-Ray Clipper(tick)(tick)
(without Mesh mode)
Cinema 4D Floor(tick)(tick)
Renderable Spline tag(tick)(tick)
Lighting
Feature
V-RayV-Ray GPU
V-Ray Lights
(tick)
(tick)
Light instancing(tick)(tick)
Image-based lighting
(tick)
(tick)
Light and shadow linking
(tick)
(tick)
Cinema 4D Omni LightPARTIALPARTIAL
Cinema 4D Spot LightPARTIALPARTIAL
Cinema 4D Infinite LightPARTIALPARTIAL
Cinema 4D Area LightPARTIALPARTIAL
Cinema 4D IES LightPARTIALPARTIAL
Cinema 4D Sun LightPARTIALPARTIAL
Cinema 4D PBR LightPARTIALPARTIAL
Global Illumination Methods
Brute Force
(tick)
(tick)
Light Cache
(tick)
(tick)
Caustics(tick)PARTIAL 1
Render Elements
Preset: Back to Beauty(tick)(tick)
Atmospheric Effects(tick)(tick)
Background
(tick)
(tick)
Bump Normals
(tick)
(tick)
Caustics
(tick)
(Production mode)
(error)
Coat Specular(tick)(tick)
Coat Filter(tick)(error)
Coat Glossiness(tick)(error)
Coat Reflection(tick)(tick)
Coverage
(tick)
 (error)
Cryptomatte
(tick)
(tick)
Denoiser
(tick)
(tick)
Diffuse
(tick)
(tick)
GI
(tick)
(tick)
LightMix(tick)(tick)
Light Select
(tick)
(tick)
Lighting
(tick)
(tick)
Material ID(tick)(tick)
Material Select(tick)(error)
Matte Shadow(tick)(error)
Normals(tick)(tick)
Object ID(tick)(tick)
Object Select(tick)(error)
Raw GI(tick)(error)
Raw Light(tick)(error)
Raw Reflection(tick)(error)
Raw Refraction(tick)(error)
Raw Shadow(tick)(error)
Raw Total Light(tick)(error)
Reflect IOR(tick)(error)
Reflection Filter(tick)(tick)
Reflection Glossiness(tick)(error)
Reflection Highlight Glossiness(tick)(error)
Refraction(tick)(tick)
Refraction Filter(tick)(tick)
Refraction glossiness(tick)(error)
Render ID(tick)(tick)
SSS(tick)(tick)
Sample Rate(tick)(tick)
Self Illumination(tick)(tick)
Shadow(tick)(tick)
Velocity(tick)(tick)
Z Depth(tick)(tick)
Materials
Al Surface(tick)(tick)
Blend
(tick)
(tick)
Car Paint 2(tick)(tick)
Light
(tick)
(tick)
(without Opacity)
V-Ray Material
(tick)
(tick)
(without Translucency,
Diffuse Roughness)
Fast SSS2
(tick)
PARTIAL
(without raytraced (solid) and raytraced (refractive))
Hair Next(tick)(tick)
Bump
(tick)
(tick)
2 Sided
(tick)
(tick)
Scanned(tick)(tick)
Textures
VRayBitmap(tick)(tick)
VRayC4DBake(tick)(tick)
VRayCurvature(tick)(tick)
VRayDirt(tick)PARTIAL
VRayDistance(tick)(tick)
VRayFalloff(tick)(tick)
VRayFresnel(tick)(tick)
VRayLayered(tick)(tick)
VRaySky(tick)(tick)
VRayTriPlanar
(tick)
VRayMultiSubTex
VRayRamp
VRayMix
VRayNormalMap
VRayUVWRandomizer(tick)(tick)
Cinema 4D Shaders
Color
(tick)
(tick)
Fresnel
PARTIAL
PARTIAL
Gradient
PARTIAL
(Except: Turbulence)
PARTIAL
Noise(tick)(tick)
Colorizer
(tick)
(tick)
FilterPARTIALPARTIAL 2
Fusion
PARTIAL
(Except: Soft Light, Dodge, Burn,
Darken, Levr blend modes)
PARTIAL
LayerPARTIALPARTIAL
Posterizer
Effects
Ambient Occlusion
(error)
(error)
Backlight
(error)
(error)
ChanLum
(error)
(error)
Distorter
(error)
(error)
Falloff
(tick)
(tick)
Lens Distortion
(error)
(error)
Lumas
(error)
(error)
Normal Direction
(error)
(error)
Normalizer
(error)
(error)
Pixel
(error)
(error)
Projector
PARTIAL
(Except: Flat, Cubic, Frontal, Spatial,
Shrink Wrapping)
PARTIAL
Shrink Wrapping)
Proximal
(error)
(error)
Ripple
(error)
(error)
Spectral
(error)
(error)
Spline
(error)
(error)
Subsurface Scattering
(error)
(error)
Terrain Mask
(error)
(error)
Thin Film
(error)
(error)
Variation
(error)
(error)
Vertex Map(tick)(tick)
Weathering
(error)
(error)
MoGraph
Beat Shader
Camera Shader
Color Shader
Multi Shader
Sketch and Toon
Art
Cel
Hatch
Spots
Surfaces
Brick
Checkerboard(tick)(tick)
Cloud
Cyclone
Display Color
Earth
Fire
Flame
Formula
Galaxy
Marble
Metal
Pavement
Planet
Rust
Simple Noise(tick)(tick)
Simple Turbulence
Starfield
Stars
Sunburst
Tiles
Venus
Water
Wood
Moves Face Shader
Polygon Hair
Substance Shader
Overrides
Material Override(tick)(tick)
Footnotes
Cinema 4D shaders marked as are supported by V-Ray via the Bake Cinema 4D Shaders option available in Render Settings > Overrides > Textures or via the VRayC4DBake texture.
1. The new Progressive Caustics method works only with the Progressive Image Sampler and on CPU.
2. The Spline Interpolation is currently not supported. The Colorize option is not supported at the moment. Positive values for Lightness in the native Filter shader do not currently produce the expected results.
3. Currently, V-Ray Scene does not import V-Ray Sky in Cinema 4D. V-Ray Scene does not refresh when working with Interactive rendering.
