Available only in Advanced mode. Thin Film – Turns on/off the thin film effect. Thickness Map – Specifies the thickness texture. The map blends between the Min and Max thickness values and is expected to be in the range of 0-1. If there is no texture map, only the minimum thickness value is used. Thickness Min (nm) – Determines the minimum thickness measured in nanometers. See the Thin Film Thickness example for more information. Thickness Max (nm) – Determines the maximum thickness measured in nanometers. IOR – Specifies the index of refraction of the medium the thin film is made of. |
