This page provides information on the Physical camera attributes.
The V-Ray Physical Camera uses real-world camera settings such as f-stop, focal length, and shutter speed to set up the virtual CG camera. It also makes it easier to use light sources with real-world illumination, such as V-Ray lights with physical units or V-Ray Sun and Sky
UI Path: V-Ray menu > Cameras > Physical Camera
General
Camera Type – Specifies the camera type. This mostly has an effect on the motion blur effect produced by the camera.
Still cam – Simulates a still photo camera with a regular shutter.
Movie cam – Simulates a motion-picture camera with a circular shutter.
Video cam – Simulates a shutter-less video camera with a CCD matrix.
Sensor and Lens
Specify Field of View – When enabled, sets the field of view directly without having to set up the film gate and focal length.
Field of View – Specifies the field of view in degrees.
Film Gate (mm) – Specifies the horizontal size of the film gate in millimeters. Note that this setting takes into account the system units configuration to produce the correct result. Vertical film gate size is calculated by accounting image aspect ratio (vertical film size = horizontal film size / aspect ratio).
Focal Length (mm) – Specifies the equivalent focal length of the camera lens. This setting takes into account the system units configuration to produce the correct result.
Zoom Factor – Specifies a zoom factor. Values greater than 1.0 zoom into the image; values smaller than 1.0 zoom out. This is similar to a blow-up rendering of the image.
Example: Exposure, Field of View and Focus Distance
The focus distance of the physical camera (as specified by either the Target distance or the Focus distance parameter) affects the exposure of the image and the field of view for the camera, especially if the focus distance is close to the camera. This is an effect that can be observed with real-world cameras as demonstrated in the images below.
The set up is a white board with a small black rectangle and a camera in front of it. Notice how changing the focus distance produces images with different brightness even though the illumination and all other camera parameters are the same in both cases. Also notice the change in the field of view.
The camera is focused on the white board; the grey color is approximately RGB 104, 104, 104.
The camera is focused at infinity; the grey color is approximately RGB 135, 135, 135.
Side view of the camera focused on the white board.
Side view of the camera focused at infinity.
Aperture
Film Speed (ISO) – Determines the film power (i.e. sensitivity). Smaller values make the image darker, while larger values make it brighter.
F-Number – Determines the width of the camera aperture and, indirectly, exposure. If the Exposure option is checked, changing the f-number will affect the image brightness.
Shutter Speed (s^-1) – Specifies the shutter speed, in inverse seconds, for the still photographic camera. For example, shutter speed of 1/30 s corresponds to a value of 30 for this parameter.
Shutter Angle Specifies the shutter angle (in degrees) for the movie camera.
Shutter Offset – Specifies the shutter offset (in degrees) for the movie camera.
Latency (s) – Specifies the CCD matrix latency (in seconds) when the camera mode is set to Video cam.
Color and Exposure
Exposure – Specifies how the F-numberShutter speed, and Film speed (ISO) settings affect the image brightness.
No Exposure – Shutter speedF-number and ISO settings do not affect the image brightness;
Physical Exposure – Image brightness is controlled by the Shutter speedF-number and ISO;
Exposure Value (EV) – Uses the Exposure value to control image brightness. Grays out the ISO parameter and uses Shutter speed and F-number values only for Motion Blur and Depth of field respectively.
Exposure Value – Controls the exposure value when the Exposure Value (EV) option is selected.
Vignetting – When enabled, simulates the optical vignetting effect of real-world cameras. The strength of the vignetting effect can be specified, where 0.0 is no vignetting and 1.0 is normal vignetting.
White Balance – Allows additional modification of the image output. Objects in the scene that have the specified color appear white in the image. Note that only the color hue is taken into consideration; the brightness of the color is ignored.
Tilt and Shift
Vertical Tilt – Vertical tilt that allows the simulation of tilt lenses for 2-point perspective.
Horizontal Tilt – Horizontal tilt that allows the simulation of tilt lenses for 2-point perspective. Changing these parameters is similar to applying a camera correction modifier.
Vertical Shift – Vertically offsets the camera field of view as a fraction of the current view. For example, a value of 0.5 offsets the camera one-half of the current image height upwards.
Horizontal Shift – Horizontally offsets the camera field of view as a fraction of the current view. For example, a value of 0.5 offsets the camera one-half of the current image width to the left.
Depth of Field
Enabled – Enables the depth of field effect. Note that depth of field depends on the Focus distance and F-Number parameters.
Bokeh Effects
Aperture Shape – Defines the shape of the camera aperture. When disabled, a perfectly circular aperture is simulated. When enabled, a polygonal aperture is simulated, with the specified number of blades.
Blades Number – Specifies the number of blades of the aperture.
Rotation – Rotates the blades (value in degrees).
Center Bias – Defines a bias shape for the bokeh effects. Positive values make the outer edge of the bokeh effects brighter; negative values make the center of the effect brighter.
Anisotropy – Allows stretching of the bokeh effect horizontally or vertically to simulate anamorphic lenses. If you want the ratio of height to width of the bokeh to be k:1,  then the value for anisotropy should be sqrt(1/k)-1For example, for anamorphic bokeh, which is 2.39:1, the anisotropy value should be -0.353.
Optical Vignetting – Controls the strength of the optical vignetting, also known as and cat's eye vignetting. This effect is due to the fact that the shape of the bokeh highlights resembles the shape of the aperture. As the distance to the optical axis increases, the bokeh highlights are progressively narrowed and begin to resemble the shape of a cat's eye. The larger the distance from the image center, the narrower the cat's eye becomes. Optical vignetting tends to be stronger in wide angle lenses and large aperture lenses, but the effect can be noticed with most photographic lenses.
Optical vignetting is currently very slow to calculate; it may introduce noise in the image that is difficult to clean.
Bitmap Aperture
Enabled – Enables the use of an image (specified in the field below) to control the aperture shape as well as any dirt or scratches that may affect the bokeh. White signifies transparent areas and black signifies opaque areas.
File – Specifies the image file.
Bitmap Resolution – Specifies the sampling texture resolution when calculating the bokeh effects.
Affect Exposure – When enabled, the bokeh effects affect the overall exposure of the image.
Motion Blur
Enabled – Enables motion blur. Note that motion blur depends on how fast the objects are moving, as well as the camera's Shutter settings.
Mode – Specifies whether the rolling shutter effect is enabled and the direction of the shutter.
Disabled
Top to bottom
Bottom to top
Left to right
Right to left
Duration (s^-1) – The time for the shutter to pass through the image in 1/seconds.
Distortion
Type – Specifies how the distortion is determined.
Quadratic – The default distortion type. It uses a simplified formula that is easier to calculate than the Cubic method.
Cubic
 – Used in some camera tracking programs like SynthEyes, Boujou, etc. If you plan on using one of these programs, this distortion type should be used.
Lens file
 – Uses a .lens file generated with the V-Ray Lens Analysis tool and specified in the Lens file field.
Texture
 – Uses a texture file generated in a third party application (i.e. Nuke) and specified in the distortion map field.
AmountSpecifies the distortion coefficient for the camera lens when the Distortion type is set to either Quadratic or Cubic. A value of 0.0 means no distortion; positive values produce "barrel" distortion, while negative values produce "pillow" distortion.
Distortion Texture When Distortion type is set to Texture, this slot specifies the map that contains the distortion data.
Lens FileWhen Distortion type is set to Lens file, this slot specifies the lens file, containing distortion data.
