After setting up LightMix (either automatically, or manually), the color and intensity of each light can be changed in the VFB. Simply go to LightMix tab in Corona VFB and change the desired parameters - this can be done during, or after rendering, for both regular and interactive rendering. You can also use additional buttons below the lights list: Scene - Bakes all LightMix colors and intensities into the scene lights. After clicking this and confirming, the image displayed in the VFB will be temporarily changed to the non-LightMix version, and you will need to re-render it to get the desired result. Lights which are instanced will become unique in case some of them were separately altered using the LightMix. Save... / Load... - Saves a LightMix preset as a .conf file. Useful, for example, when creating day and night versions of a scene. It is also possible to load a preset after a camera is changed and a different view is rendered. The .conf files can be also loaded into the Corona Image Editor. Toggle all - This enables or disables all lights in the LightMix list. All 1.0 - Reverts all LightMix layers' intensities to 1.0, which means the values set in the scene are used - this will NOT make all lights equally bright if they have different intensities set in the scene. All white - Simply reverts the colors of all LightMix layers to pure white, which results in having the initial colors of scene lights used. You can right-click on the light names on the LightMix list in the Corona VFB to select a specific light in the scene, add that light to the current selection, or remove that light from the current selection. |
