Right click on the render layer and select Create Collection. Name the collection however you like. You can add whichever objects you want to the collection. The easiest way to include all objects into a collection is through pattern matching. The Include field matches patterns. 1. Set the Collection Filters to All 2. Type * (asterisk) as a wildcard in the Include field. This matches absolutely everything in the scene. 3. Click on Select to apply the selection 4. Click on Add to add the selected items to the collection The combination of using the Collection Filters and wildcards can be used to quickly match all shape nodes, all transform nodes, etc, in case you don’t need absolutely all node types. For more information, visit the Autodesk Knowledge Network. TIP: By default, Render Setup adds all scene lights to each new layer. If you need to add just some of the lights - make sure the Include all lights in each render layer by default option is disabled. It is located under the Render Setup Options tab. |
