This page offers information about the Spot Light Details rollout in Chaos Vantage.
||Top toolbar|| > Create new Light object
||Right side panel|| > Objects tab > Create new Light object > Spot
The following examples demonstrate the effect that individual Spot Light parameters have on the scene. Click on any image to view it at a higher resolution.
This example shows the effect of the Color parameter.
Color is red
Color is green
Color is blue
This example shows the effect of the Shape type parameter.
Shape type = Circle
Shape type = Rectangle
Shape type = Smooth rectangle
This example shows the effect of the Hotspot parameter.
Hotspot = 0
Hotspot = 10
Hotspot = 45
This example shows the effect of the Falloff parameter.
Falloff = 10
Falloff = 45
Falloff = 90
This example shows the effect of the Decay type parameter.
Decay type = None
Decay type = Inverse
Decay type = Inverse square
This example shows the effect of the Decay start parameter.
Decay start = 1
Decay start = 3
Decay start = 5
This example shows the effect of the Overshoot parameter.
Overshoot is off
Overshoot is on
This example shows the effect of the Affect diffuse parameter.
Affect diffuse is off
Affect diffuse is on
