VRay SDK for C++
Loading...
Searching...
No Matches
VRay::LightUtils Class Reference
A group of utility methods related to variuos light source plugins. More...
#include <vraysdk.hpp>
Static Public Member Functions
static bool readIESPreviewData (const Plugin &lightPlugin, VectorList &vertices, IntList &indices)
static bool readIESPreviewData (const std::string &fileName, VectorList &vertices, IntList &indices)
static bool readLuminaireFieldPreviewData (const Plugin &luminairePlugin, LuminaireFieldReadPreviewData &readData)
static bool readLuminaireFieldPreviewData (const std::string &fileName, LuminaireFieldReadPreviewData &readData)
Detailed Description
Member Function Documentation
◆ readIESPreviewData() [1/2]
static bool VRay::LightUtils::readIESPreviewData ( const Plugin &  lightPlugin,
VectorList &  vertices,
IntList &  indices
static
lightPluginA LightIES plugin instance
verticesOutput vertex preview data.
indicesOutput face index data. Each three consecutive elements make up one triangle.
Returns
false if an error ocurred. Check getLastError() for additional info.
◆ readIESPreviewData() [2/2]
static bool VRay::LightUtils::readIESPreviewData ( const std::string &  fileName,
IntList &  indices
static
fileNameIES file name (.ies)
Returns
◆ readLuminaireFieldPreviewData() [1/2]
static bool VRay::LightUtils::readLuminaireFieldPreviewData ( const Plugin &  luminairePlugin,
LuminaireFieldReadPreviewData &  readData
static
luminairePluginA LightLuminaire plugin instance
readDataA structure handle which provides an API for getting the preview data relating to light luminaire field.
Returns
◆ readLuminaireFieldPreviewData() [2/2]
static bool VRay::LightUtils::readLuminaireFieldPreviewData ( const std::string &  fileName,
static
fileNameLuminaire cache file name (.vlw|.vlg|.vlsh)
Returns
The documentation for this class was generated from the following file:
