VRay SDK for C++
#include <vraysdk.hpp>
Public Member Functions | |
| PluginRefT () noexcept | |
| Default construct an invalid PluginRef - not referencing a V-Ray scene object. | |
| PluginRefT (const PluginRefT &plugin) noexcept | |
| Copy construct from another PluginRef. | |
| template<class X > | |
| PluginRefT (const PluginRefT< X > &plugin) noexcept | |
| PluginRefT (const T &plugin) noexcept | |
| Construct from another Plugin. | |
| PluginRefT (const T &plugin, const char *outPropertyName) | |
| Construct from Plugin and output property. | |
| PluginRefT (const X &plugin) noexcept | |
| const char * | getOutputName () const |
| bool | isOutputValid () const noexcept |
| Returns true if this PluginRef references a valid Plugin output (including the default one). | |
| bool | operator< (const PluginRefT &plugin) const noexcept |
| bool | operator< (const PluginRefT< Plugin > &plugin) const noexcept |
| bool | operator<= (const PluginRefT &plugin) const noexcept |
| bool | operator<= (const PluginRefT< Plugin > &plugin) const noexcept |
| PluginRefT & | operator= (const PluginRefT &plugin) noexcept |
| Assign from another PluginRefT. They both point to the same underlying object. This is like having T& a=x; T& b=x;. | |
| bool | operator== (const Plugin &plugin) const noexcept |
| Returns true if both Plugins point to the same scene object instance. | |
| bool | operator== (const PluginRefT &plugin) const noexcept |
| Returns true if both PluginRefTs point to the same scene object instance and reference the same output. | |
| bool | operator== (const PluginRefT< Plugin > &plugin) const noexcept |
| bool | operator> (const PluginRefT &plugin) const noexcept |
| bool | operator> (const PluginRefT< Plugin > &plugin) const noexcept |
| bool | operator>= (const PluginRefT &plugin) const noexcept |
| bool | operator>= (const PluginRefT< Plugin > &plugin) const noexcept |
| void | swap (PluginRefT &plugin) noexcept |
| Swaps the underlying scene object instance reference along with its output and associated renderer reference. | |
| std::string | toString () const |
| Returns a string representation of the plugin reference of the form "pluginName::outputPropertyName". | |
Friends | |
| template<class U > | |
| std::ostream & | operator<< (std::ostream &stream, const PluginRefT< U > &pluginRef) |
| class | PluginRefT< Plugin > |
| class | VRayRenderer |
PluginRef extends Plugin to hold a plugin property output as well. PluginRefT<class T> where T is a typed plugin class is a typed version of PluginRef. Instances of PluginRef are used when a property value is read or set. Plugin instances are convertible to PluginRefs; and vice versa with information loss. PluginRefT<T> can be implicitly converted to PluginRef. PluginRef can be converted to PluginRefT<T> with plugin_cast or plugin_checked_cast.
| const char * VRay::PluginRefT< T >::getOutputName | ( | ) | const |
Get the name of the Plugin output this reference contains. Returns nullptr if it's the default or invalid output.
