VRay SDK for C++
Loading...
Searching...
No Matches
VRay::ScenePreview Class Reference
Classes
class  Object
struct  Particle
struct  Settings
struct  Sizes2D
struct  Sizes3D
Public Types
enum  DataType {
  DataTypeAll = -1 , DataTypeNoData = 0 , DataTypeMesh = (1 << 0) , DataTypeHair = (1 << 1) ,
  DataTypeParticles = (1 << 2) , DataTypeVolume = (1 << 3) , DataTypeInfinitePlane = (1 << 4) , DataTypeInstancer2 = (1 << 5) ,
  DataTypeVRayProxy = (1 << 6) , DataTypeRayserverInstancer = (1 << 7) , DataTypeStaticMesh = (1 << 8) , DataTypePerfectSphere = (1 << 9) ,
  DataTypeGeomInstancer = (1 << 10) , DataTypeHasInstances = DataTypeInstancer2 | DataTypeRayserverInstancer | DataTypeGeomInstancer , ObjectDataTypeAll = DataTypeAll , ObjectDataTypeNoData = DataTypeNoData ,
  ObjectDataTypeMesh = DataTypeMesh , ObjectDataTypeHair = DataTypeHair , ObjectDataTypeParticles = DataTypeParticles , ObjectDataTypeVolume = DataTypeVolume ,
  ObjectDataTypeInfinitePlane = DataTypeInfinitePlane , ObjectDataTypeInstancer2 = DataTypeInstancer2 , ObjectDataTypeVRayProxy = DataTypeVRayProxy , ObjectDataTypeRayserverInstancer = DataTypeRayserverInstancer ,
  ObjectDataTypeStaticMesh = DataTypeStaticMesh , ObjectDataTypePerfectSphere = DataTypePerfectSphere , ObjectDataTypeGeomInstancer = DataTypeGeomInstancer , ObjectDataTypeHasInstances = DataTypeHasInstances
enum  LightType {
  LightTypeUnsupported = 0 , LightTypeOmni , LightTypeRectangle , LightTypeSphere ,
  LightTypeDirect , LightTypeSpot , LightTypeSun , LightTypeIES ,
  LightTypeDome , LightTypeMesh
enum  ObjectType {
  ObjectTypeAll = 0 , ObjectTypeNode , ObjectTypeNodeParticle , ObjectTypeLight ,
  ObjectTypeInstancer , ObjectTypeVolume , ObjectTypeVRayScene , ObjectTypeMaterial ,
  ObjectTypeDecal , ObjectTypeClipper
enum  UpAxis { UpAxisUnknown = -1 , UpAxisZ = 0 , UpAxisY }
Public Member Functions
 ScenePreview (const char *filename)
 ScenePreview (const char *filename, const Settings &settings)
int getFPS () const
 Returns FPS.
int getFrameEnd () const
 Returns animation end frame.
float getFramesScale () const
 Returns scene frames scale.
int getFrameStart () const
 Returns animation start frame.
float getMetersScale () const
 Returns scene meters scale.
Object getObject (const char *name) const
std::vector< Object > getObjects (ObjectType objectType=ObjectTypeAll, DataType dataType=DataTypeAll) const
float getPhotometricScale () const
 Returns scene photometric scale.
float getSecondsScale () const
 Returns scene seconds scale.
size_t getTotalFaces () const
 Returns the total number of faces.
UpAxis getUpAxis () const
 Returns scene up axis.
 operator bool () const
bool operator! () const
Constructor & Destructor Documentation
◆ ScenePreview() [1/2]
VRay::ScenePreview::ScenePreview ( const char *  filename)
explicit
Constructs a ScenePreview container from the given scene file. If exceptions are not disabled, throws FileReadErr().
filenameThe file to extract preview info from.
◆ ScenePreview() [2/2]
VRay::ScenePreview::ScenePreview ( const char *  filename,
const Settings &  settings
settingsAdditional params. See ScenePreview::Settings struct.
Member Function Documentation
◆ getObject()
Object VRay::ScenePreview::getObject ( const char *  name) const
Returns a scene object by name.
nameAn object name (a plugin name in the vrscene-file).
Returns
The scene object. May be invalid/empty.
◆ getObjects()
std::vector< Object > VRay::ScenePreview::getObjects ( ObjectType  objectType = ObjectTypeAll,
DataType  dataType = DataTypeAll
) const
Returns all or some of the objects contained in the scene file.
objectTypeSpecifies what type of object to return. Default is all types.
dataTypeSpecifies what data the returned objects have to contain. More than one type can be specified e.g. DataType(DataTypeHair | DataTypeParticles). Default is all data types.
Returns
A vector containing the scene objects.
◆ operator bool()
VRay::ScenePreview::operator bool ( ) const
inline
If exceptions are disabled check if the container holds valid data.
Returns
true if the container holds valid data.
◆ operator!()
bool VRay::ScenePreview::operator! ( ) const
inline
Returns
true if the container doesn't hold valid data.
The documentation for this class was generated from the following file:
