VRay SDK for C++
Loading...
Searching...
No Matches
VRay::BinUserAttributesWriter Struct Reference
Attributes storage format: [attrName\0|type{uint8}|value{some_bytes}][...][...]\0. More...
#include <vraysdk.hpp>
Public Types
enum  BinUserAttributeType : byte {
  binUserAttributeType_int = 0 , binUserAttributeType_float , binUserAttributeType_vector , binUserAttributeType_acolor ,
  binUserAttributeType_string , binUserAttributeType_last
enum  BinUserAttributeTypeFlags : byte { binUserAttributeFlag_small = 1 << 3 , binUserAttributeFlag_smallY = 1 << 2 , binUserAttributeFlag_smallZ = 1 << 1 , binUserAttributeFlag_smallA = 1 << 0 }
Public Member Functions
void add (const char *name, size_t nameLen, const AColor &value)
void add (const char *name, size_t nameLen, const char *value, size_t valueLen)
void add (const char *name, size_t nameLen, const Vector &value)
void add (const char *name, size_t nameLen, float value)
void add (const char *name, size_t nameLen, int value)
template<size_t count>
void add (const char(&name)[count], const AColor &value)
void add (const char(&name)[count], const Vector &value)
void add (const char(&name)[count], float value)
void add (const char(&name)[count], int value)
template<size_t nameLen>
void add (const char(&name)[nameLen], const char *value, size_t valueLen)
template<size_t nameLen, size_t valueLen>
void add (const char(&name)[nameLen], const char(&value)[valueLen])
void add (const char(&name)[nameLen], const std::string &value)
void add (const std::string &name, const AColor &value)
void add (const std::string &name, const char *value, size_t valueLen)
template<size_t valueLen>
void add (const std::string &name, const char(&value)[valueLen])
void add (const std::string &name, const std::string &value)
void add (const std::string &name, const Vector &value)
void add (const std::string &name, float value)
void add (const std::string &name, int value)
void close ()
size_t getNumBytes () const
 Get number of written bytes.
bool hasData () const
 Checks if we've written any attributes.
IntList toIntList ()
std::string toString () const
Detailed Description
Member Enumeration Documentation
◆ BinUserAttributeType
Attribute type format: uint8 76543210 00000000 ||||~~~~ - Attribute type. |||- AColor.alpha is small. ||- Vector.z is small. |- Vector.y is small. - Int, float or vector.x is small.
◆ BinUserAttributeTypeFlags
Enumerator
Means that int, float or vector.x value fits in int8. Basically used to store values like 0.0 or 1.0 more efficiently.
Vector.y component is a small value.
Vector.z component is a small value.
AColor.alpha component is a small value.
Member Function Documentation
◆ add() [1/19]
void VRay::BinUserAttributesWriter::add ( const char *  name,
size_t  nameLen,
const AColor &  value
inline
Append color attribute.
nameAttribute name.
nameLenAttribute name length.
valueColor value.
◆ add() [2/19]
size_t  nameLen,
const char *  value,
size_t  valueLen
inline
Append string attribute.
nameAttribute name.
valueString value.
valueLenString value length.
◆ add() [3/19]
size_t  nameLen,
const Vector &  value
inline
Append vector attribute.
nameAttribute name.
valueVector value.
◆ add() [4/19]
size_t  nameLen,
float  value
inline
Append float attribute.
nameAttribute name.
valueFloat value.
◆ add() [5/19]
size_t  nameLen,
int  value
inline
Append integer attribute.
nameAttribute name.
valueInteger value.
◆ add() [6/19]
void VRay::BinUserAttributesWriter::add ( const char(&)  name[count],
inline
nameAttribute name.
valueAColor value.
◆ add() [7/19]
inline
nameAttribute name.
valueVector value.
◆ add() [8/19]
float  value
inline
nameAttribute name.
valueFloat value.
◆ add() [9/19]
int  value
inline
nameAttribute name.
valueInteger value.
◆ add() [10/19]
void VRay::BinUserAttributesWriter::add ( const char(&)  name[nameLen],
const char *  value,
size_t  valueLen
inline
nameAttribute name.
valueString value.
◆ add() [11/19]
const char(&)  value[valueLen]
inline
nameAttribute name.
valueString value.
◆ add() [12/19]
const std::string &  value
inline
nameAttribute name.
valueString value.
◆ add() [13/19]
void VRay::BinUserAttributesWriter::add ( const std::string &  name,
inline
nameAttribute name.
valueAColor value.
◆ add() [14/19]
const char *  value,
size_t  valueLen
inline
nameAttribute name.
valueString value.
◆ add() [15/19]
inline
nameAttribute name.
valueString value.
◆ add() [16/19]
inline
nameAttribute name.
valueString value.
◆ add() [17/19]
inline
nameAttribute name.
valueVector value.
◆ add() [18/19]
float  value
inline
nameAttribute name.
valueFloat value.
◆ add() [19/19]
int  value
inline
nameAttribute name.
valueInteger value.
◆ close()
void VRay::BinUserAttributesWriter::close ( )
inline
Finalize attributes per instance. Call close() to separate attributes between different instances.
◆ toIntList()
IntList VRay::BinUserAttributesWriter::toIntList ( )
inline
Get binary serialized data as IntList for easier assignment as plugin property value. This will reset the state of BinUserAttributesWriter!
◆ toString()
std::string VRay::BinUserAttributesWriter::toString ( ) const
inline
Returns the hex string representation that is written to the returned IntList including the final 0 character.
The documentation for this struct was generated from the following file:
