VRay SDK for C++
Loading...
Searching...
No Matches
VRay::DenoiserOptions Struct Reference
Public Types
enum  FlagVal : byte { Disabled = 0 , Enabled = 1 , Default = 0xFF }
Public Member Functions
 DenoiserOptions (const DenoiserOptions &options)=default
DenoiserOptions & operator= (const DenoiserOptions &options)=default
Public Attributes
FlagVal allowInSingleChannelFiles
 True to allow writing to single channel files too. Off by default.
FlagVal hideDest
 Hide destination channel in VFB.
FlagVal optixUpscale
 True if the optix denoiser should use the upscaling mode. Does nothing for other engines.
FlagVal panorama
 True if denoised image is wrapped around the left/right border.
FlagVal skipAlpha
 True if the alpha channel should NOT be denoised.
FlagVal skipAuxElementsInFiles
 True to skip writing the additional channels to files.
Member Enumeration Documentation
◆ FlagVal
Enumerator
Enabled
Will reset the flag.
Default
Will set the flag.
The documentation for this struct was generated from the following file:
