Parameters for setLicenseServer(). Only serverName is obligatory.
More...
#include <vraysdk.hpp>
std::string | certificateFilePath |
std::string | password |
| | For the optional login.
std::string | proxyName |
| | Optional http proxy server.
std::string | proxyPassword |
| | Login for the optional proxy server.
int | proxyPort |
std::string | proxyUserName |
int | safeModeFlags |
| | Do not use without explicit instructions. Added as precaution.
std::string | secureServer |
| | Must be set to "ols.chaos.com" to use the Chaos Cloud licensing.
std::string | serverName |
| | Primary license server - hostname or IP address.
std::string | serverName1 |
| | Optional alternative server if the primary doesn't work.
std::string | serverName2 |
| | Optional second alternative server.
int | serverPort |
| | default port is 30304
int | serverPort1 |
int | serverPort2 |
bool | useCustomCertificate |
| | True to enable the usage of the custom certificate file path to be used for secure connection.
std::string | username |
| | Optional login.
bool | useSecureConnection |
| | Must be true to enable the secure connection.
The documentation for this struct was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
