VRay SDK for C++
Loading...
Searching...
No Matches
VRay::Matrix Struct Reference
3x3 column-major matrix, float32 More...
#include <vraysdk.hpp>
Public Member Functions
 Matrix () noexcept=default
 Constructor - initializes all components to zero.
 Matrix (const Matrix &) noexcept=default
 Matrix (const Vector &a, const Vector &b, const Vector &c) noexcept
 Matrix (float value) noexcept
 Constructor to diagonal matrix.
 Matrix (Matrix &&) noexcept=default
 Matrix (Vector diagonal) noexcept
void addDiagonal (const Vector &a) noexcept
void addTranspose (const Matrix &b) noexcept
void makeDiagonal (const Vector &a) noexcept
void makeIdentity (void) noexcept
 Make the matrix the identity matrix.
bool makeInverse (void) noexcept
void makeOrthogonal (void) noexcept
void makeOrthonormal (void) noexcept
void makeOuterProduct (const Vector &a, const Vector &b) noexcept
void makeTranspose (void) noexcept
 Make the matrix to be the transpose of its currrent value.
void makeZero (void) noexcept
 Make the matrix the zero matrix (all elements are zeroes).
void operator*= (float x) noexcept
 Multiply all elements in the matrix by the given number.
void operator+= (const Matrix &m) noexcept
void operator-= (const Matrix &m) noexcept
void operator/= (float x) noexcept
 Divide all elements in the matrix by the given number. Does not perform a check for divide by zero.
Matrix & operator= (const Matrix &) noexcept=default
Matrix & operator= (Matrix &&) noexcept=default
const Vector & operator[] (const int index) const noexcept
 Return the i-th column of the matrix as a const object (i=0,1,2).
Vector & operator[] (const int index) noexcept
 Return the i-th column of the matrix (i=0,1,2).
void rotate (const Vector &axis) noexcept
 Applies a rotation along the given axis. The length of the axis is the tangent of the angle of rotation.
void set (const Matrix &other) noexcept
void set (const Vector &a, const Vector &b, const Vector &c) noexcept
void set (float value) noexcept
 Make diagonal matrix.
void setCol (const int i, const Vector &a) noexcept
void setRow (const int i, const Vector &a) noexcept
std::string toString () const
Public Attributes
Vector v0
Vector v1
Vector v2
Related Functions
(Note that these are not member functions.)
Matrix inverse (const Matrix &m) noexcept
Matrix makeMatrixFromRowMajor (const Vector &a, const Vector &b, const Vector &c) noexcept
Matrix makeRotationMatrixX (float xrot) noexcept
Matrix makeRotationMatrixY (float yrot) noexcept
Matrix makeRotationMatrixZ (float zrot) noexcept
Matrix normalize (const Matrix &m) noexcept
Matrix noScale (const Matrix &m) noexcept
bool operator!= (const Matrix &a, const Matrix &b) noexcept
Matrix operator* (const Matrix &a, const Matrix &b) noexcept
Vector operator* (const Matrix &m, const Vector &a) noexcept
Matrix operator* (const Matrix &m, float x) noexcept
Vector operator* (const Vector &a, const Matrix &m) noexcept
Matrix operator* (float x, const Matrix &m) noexcept
Matrix operator+ (const Matrix &a, const Matrix &b) noexcept
Matrix operator- (const Matrix &a) noexcept
Matrix operator- (const Matrix &a, const Matrix &b) noexcept
Matrix operator/ (const Matrix &m, float x) noexcept
float operator/ (float x, const Matrix &m) noexcept
bool operator== (const Matrix &a, const Matrix &b) noexcept
Matrix operator^ (const Matrix &m, const Vector &a) noexcept
Matrix operator^ (const Vector &a, const Matrix &m) noexcept
Matrix rotate (const Matrix &m, const Vector &axis) noexcept
Vector rotationAngles (const Matrix &m) noexcept
Vector scale (const Matrix &m) noexcept
void simpleDecompose (const Matrix &m, Vector &rotation, Vector &scale, Vector &shear) noexcept
Matrix transpose (const Matrix &m) noexcept
Detailed Description
Constructor & Destructor Documentation
◆ Matrix()
VRay::Matrix::Matrix ( const Vector &  a,
const Vector &  b,
const Vector &  c
inlinenoexcept
Constructor from the three columns of the matrix.
aThe first column.
bThe second column.
cThe third column.
Member Function Documentation
◆ makeDiagonal()
void VRay::Matrix::makeDiagonal ( const Vector &  a)
inlinenoexcept
Make the matrix a diagonal matrix with the given elements along the diagonal.
aA vector holding the diagonal values. All other elements are initialized to zeroes.
◆ makeInverse()
bool VRay::Matrix::makeInverse ( void  )
inlinenoexcept
Make the matrix to be the inverse of its current value. Checks if the matrix determinant is zero and in that case, zeroes out the matrix.
Returns
zero if the determinant is zero, and non-zero otherwise.
◆ operator+=()
void VRay::Matrix::operator+= ( const Matrix &  m)
inlinenoexcept
Add another matrix to this one.
mThe matrix to add.
◆ operator-=()
void VRay::Matrix::operator-= ( const Matrix &  m)
inlinenoexcept
Subtract another matrix from this one.
mThe matrix to subtract.
◆ set() [1/2]
void VRay::Matrix::set ( const Matrix &  other)
inlinenoexcept
Set the matrix from another matrix.
otherThe other matrix.
◆ set() [2/2]
void VRay::Matrix::set ( const Vector &  a,
const Vector &  b,
const Vector &  c
inlinenoexcept
Copy-constructor from another matrix.
otherThe other matrix. Set the columns of the matrix.
aThe first column.
bThe second column.
cThe third column.
◆ setCol()
void VRay::Matrix::setCol ( const int  i,
const Vector &  a
inlinenoexcept
Set the i-th column of the matrix.
iThe index of the column to set (i=0,1,2).
aThe value for the column.
◆ setRow()
void VRay::Matrix::setRow ( const int  i,
const Vector &  a
inlinenoexcept
Set the i-th row of the matrix.
iThe index of the row to set (i=0,1,2).
aThe value of the row.
Friends And Related Function Documentation
◆ inverse()
Matrix inverse ( const Matrix &  m)
related
Compute the inverse of a matrix.
◆ makeMatrixFromRowMajor()
Matrix makeMatrixFromRowMajor ( const Vector &  a,
const Vector &  b,
const Vector &  c
related
Create a matrix from three row-major vectors. The Matrix is still stored in COLUMN-major order.
◆ makeRotationMatrixX()
Matrix makeRotationMatrixX ( float  xrot)
related
Creates a new matrix representing a linear transformation - rotation around the X axis
xrotAngle in radians
◆ makeRotationMatrixY()
Matrix makeRotationMatrixY ( float  yrot)
related
Creates a new matrix representing a linear transformation - rotation around the Y axis
yrotAngle in radians
◆ makeRotationMatrixZ()
Matrix makeRotationMatrixZ ( float  zrot)
related
Creates a new matrix representing a linear transformation - rotation around the Z axis
zrotAngle in radians
◆ normalize()
Matrix normalize ( const Matrix &  m)
related
Make a matrix orthonormal
◆ noScale()
Matrix noScale ( const Matrix &  m)
related
Remove scaling from a matrix (make all column unit vectors)
◆ operator!=()
bool operator!= ( const Matrix &  a,
const Matrix &  b
related
Checks two matrices for inequality.
◆ operator*() [1/5]
Matrix operator* ( const Matrix &  a,
const Matrix &  b
related
Multiply two matrices, so that if p is a Vector, (a*b)*p == a*(b*p).
◆ operator*() [2/5]
Vector operator* ( const Matrix &  m,
const Vector &  a
related
Multiply a matrix by a vector. Note that this is different from multiplying the same vector by the same matrix.
◆ operator*() [3/5]
Matrix operator* ( const Matrix &  m,
float  x
related
Multiply a matrix by a number.
◆ operator*() [4/5]
Vector operator* ( const Vector &  a,
const Matrix &  m
related
Multiply a vector by a matrix. Note that this is different from multiplying the matrix by the same vector.
◆ operator*() [5/5]
Matrix operator* ( float  x,
const Matrix &  m
related
Multiply a number by a matrix. This is the same as multiplying the matrix by the number.
◆ operator+()
Matrix operator+ ( const Matrix &  a,
const Matrix &  b
related
Add two matrices, so that if p is a Vector, (a+b)*p == (a*p)+(b*p).
◆ operator-() [1/2]
Matrix operator- ( const Matrix &  a)
related
Invert the signs of all elements in a matrix.
◆ operator-() [2/2]
Matrix operator- ( const Matrix &  a,
const Matrix &  b
related
Subtract two matrices, so that if p is a Vector, (a-b)*p == (a*p)-(b*p).
◆ operator/() [1/2]
Matrix operator/ ( const Matrix &  m,
float  x
related
Divide all elements of the matrix by a given number. Does not check if the number is zero.
◆ operator/() [2/2]
float operator/ ( float  x,
const Matrix &  m
related
Divide a number by the determinant of a matrix. Does not check if the determinant is zero.
◆ operator==()
bool operator== ( const Matrix &  a,
const Matrix &  b
related
Checks two matrices for exact equality. NOTE: You may want to perform your own approximate comparison, element by element
◆ operator^() [1/2]
Matrix operator^ ( const Matrix &  m,
const Vector &  a
related
Cross product of a matrix and a vector.
◆ operator^() [2/2]
Matrix operator^ ( const Vector &  a,
const Matrix &  m
related
Cross product of a vector and a matrix.
◆ rotate()
Matrix rotate ( const Matrix &  m,
const Vector &  axis
related
◆ rotationAngles()
Vector rotationAngles ( const Matrix &  m)
related
Gets the Euler angles that are used to form the rotational part of the matrix
◆ scale()
Vector scale ( const Matrix &  m)
related
Gets the scaling vector from the matrix
◆ simpleDecompose()
void simpleDecompose ( const Matrix &  m,
Vector &  rotation,
Vector &  scale,
Vector &  shear
related
Decompose a transformation matrix into its primitive parts
[in]mNon-singular input matrix
[out]rotationThe X/Y/Z rotations in radians
[out]scaleScale factors - could be negative
[out]shearXY/XZ/YZ shear values
Note
The X/Y/Z angles can be viewed as roll/pitch/yaw. The Y (pitch) rotation is limited to +-pi/2 while the others are up to +-pi
The documentation for this struct was generated from the following file:
