A container for the data necessary to a export vrmesh with geometry, hair or particles. Used by VRay::Proxy::createMeshFile()
More...
#include <vraysdk.hpp>
ValueList | edgeVisibility |
| | ValueList( IntList ) (single frame) OR ValueList( ValueList(int, IntList ) ) (multiple frames - where int is the corresponding keyFrame)
ValueList | faceMtlIDs |
ValueList | faceNormals |
ValueList | faces |
ValueList | hairVertices |
| | ValueList( VectorList ) (single frame) OR ValueList( ValueList(int, VectorList) ) (multiple frames - where int is the corresponding keyFrame)
ValueList | hairVerticesPerStrand |
ValueList | hairWidths |
| | ValueList( FloatList ) (single frame) OR ValueList( ValueList(int, FloatList ) ) (multiple frames - where int is the corresponding keyFrame)
ValueList | mapChannels |
| | ValueList( ValueList(int, VectorList, IntList) )
ValueList | mapChNames |
| | ValueList( StringList )
ValueList | normals |
ValueList | particleVertices |
ValueList | particleWidths |
ValueList | shaderNames |
| | ValueList( ValueList(int, string) )
ValueList | velocities |
ValueList | vertices |
The documentation for this struct was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
