std::vector< OSLInputParameter > | inputParams |
| | Input parameters defined in the shader file.
std::vector< std::string > | outputClosureParams |
| | Output closure parameters defined in the shader file.
std::vector< std::string > | outputColorParams |
| | Output color parameters defined in the shader file.
std::vector< std::string > | outputFloatParams |
| | Output float parameters defined in the shader file.
The documentation for this struct was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
