The necessary parameters for reading data in a proxy file.
More...
#include <vraysdk.hpp>
float | anim_offset |
| | animated proxy initial frame offset
float | anim_speed |
| | animated proxy playback speed
int | anim_type |
| | animated proxy playback type(0 - loop; 1 - once; 2 - ping - pong; 3 - still)
bool | compute_bbox |
| | true to compute the bounding box, false to read it from the file
int | compute_normals |
| | true to calculate smooth normals
std::string | file |
| | file name to read
int | flip_axis |
| | 0 do not rotate; 1 transform from Maya to 3dsMax coordinate system (90 deg. rotation around x axis); 2 transform from 3dsMax to Maya (-90 deg. rotation around x axis)
float | fps |
| | frames per second for calculation of current time and frame
float | hair_width_multiplier |
| | a multiplier to the hair width data
bool | instancing |
| | turns on/off the instancing of Alembic duplicated objects
int | num_preview_faces |
| | number of faces in preview
std::string | object_path |
| | starting object path in Alembic hierarchy
float | particle_width_multiplier |
| | a multiplier to the particle width data
float | smooth_angle |
| | smooth angle in degrees
bool | subdiv_all_meshes |
| | true to subdivide Alembic PolyMesh and SubD objects; false to subdivide only SubD objects
int | subdiv_level |
| | the subdivision level
bool | subdiv_preserve_geom_borders |
| | if true, the borders won't be subdivided
int | subdiv_preserve_map_borders |
| | determines the smoothing mode of the mapping channels' borders. 0-None, 1-Internal and 2-All
bool | subdiv_uvs |
| | subdivide or skip mapping channels
bool | use_alembic_offset |
| | true to use Alembic animation frame offset
bool | use_full_names |
| | read the full path instead of only the name
The documentation for this struct was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
