◆ deleteResumableFileOnSuccess
| bool VRay::ResumableRenderingOptions::deleteResumableFileOnSuccess |
If set, the resumable file will be deleted automatically if the frame is completed successfully. This applies to sidecar .vrimg or .vrprog files, it doesn't apply when a .vrimg file is set as the main output.
◆ outputFileName
| std::string VRay::ResumableRenderingOptions::outputFileName |
Optional output path. This is needed when SettingsOutput.img_file is not set. (Currently only for progressive rendering. Extension is replaced with .vrprog)
◆ progressiveAutoSaveSeconds
| int VRay::ResumableRenderingOptions::progressiveAutoSaveSeconds |
Interval for saving intermediate (.vrprog) files. If set to 0 a file will only be saved at the end of the rendering. It can still be resumed at a lower noise threshold or higher time/sample limit.
The documentation for this struct was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
