float | bumpmul |
| | Plain materials strategy.
float | bumpstart |
| | Bump multiplier for the inclined views.
float | ccbump |
| | Displacement multiplier.
float | ccior |
float | ccmetalrefl |
| | Multiplier of the indirect light, used to handle the fluorescent materials by putting value below 1 in this member.
float | ccmul |
float | depthmul |
| | The z-value of the view vector below which bump is gradualy applied.
int | flakes |
| | Brightness multiplier for self shadowing.
int | forcebrdf |
| | Used to render materials with sharp sparks, a procedural map with relative size this param is used to feed the RR sampling.
float | free4 |
| | the material thumnail relative offset - this is kind of a hack, using the place of an old obsolete parameter to get fast access to the material thumbnail
float | free5 |
float | free6 |
float | free7 |
| | CC specular multiplier (Not used anymore)
float | fuzzy |
| | Controls the pure reflective behavior for inclined angles, a feature typical for brushed metal.
float | indmul |
| | When flakes is nonzero (spark mode) this parameter specifies to not scramble the uv coordinates.
int | keepflakesuv |
| | Not used anymore (set to 1)
float | lfsizecm |
| | value used to control the function converting translucency to transparency
float | orggls |
| | Clear coat noise-like bump amount (there is separate hmap bump)
float | orgglvar |
| | the clear coat glossiness the inverse angle deviation width (60 is one degree), since 20.04.21 this is real preset, but the old materials use specbell
int | plain |
| | ClearCoat index of reflection.
float | scratchdens |
float | shdhmul |
| | Clear coat effect multiplier.
float | shdmul |
| | Height multiplier for self shadowing.
float | specbell |
| | Controls how to use the smooth brdf model.
float | specmul |
| | CC specular highlights, inverse bell width (60 is one degree)
float | thickness |
int | thumbpos |
| | the clearcoat glossiness variation (0-none 1-the shallow anglesare glossy), since 20.04.21 this is real preset, but the old materials use scratchdens
float | topvLs_A |
| | Used mostly with top view fabrics, modifies the rendering of the inclined views making them blurred and fuzzy.
float | topvLs_B |
| | Used in top view materials to control the light direction correction.
float | transpf |
| | used to force triplanar mapping when certain customer has old vray (luxottica)
int | triplanar |
| | The sample thickness in mm, used to introduce alpha/translucency correction of thick materials.
A structure containing some parameter values considered optimal for the rendering of the material for example the ccior, you can add clear coat to any material by the UI, but the car paints should have ior by default, so in this structure we keep the values that must be set when the material is just created. Not all the members are used, this is because the structure is stored in the file as single block and removing a member will destroy the compatibility. Not all the members have corresponding member in the VRScansPrm, this is because it's considered pointless to make them tweakable, for example the flakes member is used directly, it's not tweakable.
