VRay SDK for C++
The necessary parameters for reading the data in the preset config file (.mbc) More...
#include <vraysdk.hpp>
Public Attributes | |
| std::string | fileName |
| Scatter preset config file (.mbc) | |
| bool | isYAxisUp |
| If true - process as if Y is up axis and otherwise default to Z. | |
| Plugin | scatterPlugin |
| A GeomScatter plugin instance to be filled by the Scatter preset config. | |
| float | unitRescale |
| Rescale to specific callers units setup, e.g. the default Cosmos asset units are centimeters, but the scatter presets data might be in meters. | |
