This page provides information about the supported .vrscene features exported from Cinema 4D.
Standard Cinema 4D Lights
UI CategoryNative nameV-Ray plugin name (plugin/parameter)Support
Light
Basic
Viewport Visibility
-(minus)
Render Visibility-(tick)
Enabled-(tick)
Coordinates
Coordinates
transform
(tick)
GeneralColorcolor(tick)
Use Temperature-(tick)
Color Temperaturecolor(tick)
Intensityintensity(tick)
Type:
Omni
Spot
Infinite
Area
IES
LightOmni
LightSpot
LightDirect / SunLight(with Sun tag)
LightRectangle
LightIES
(tick)
(tick)
(tick)
(tick)
(tick)
Shadow:
None
Shadow Maps (Soft)
Raytraced (Hard)
Area
(minus)
(minus)
(minus)
(minus)
Visible Light:
None
Visible
Volumetric
Inverse Volumetric
(minus)
(minus)
(minus)
(minus)
No Illumination-(minus)
Ambient Illumination-(minus)
Diffuse
(minus)
Specular-(minus)
GI Illumination-(minus)
Show Illumination-(minus)
Show Visible Light-(minus)
Show Clipping-(minus)
Separate Pass-(minus)
Export to Compositing-(minus)
Details
-(minus)
Use Gradient
Color
Load Preset
Save Preset
Near Clip
Far Clip
Area Shape:
Disc
Rectangle
Line
Sphere
Cylinder
Cylinder (Perpendicular)
Cube
Hemisphere
Object/Spline
Object
Size X
Size Y
Size Z
Falloff Angle
Samples
Add Grain (Slow)
Show in Render
Show as Solid in Viewport
Show in Specular
Show in Reflection
VisibilityUse Falloff-(minus)
Shadow
Shadow:
None
Shadow Maps (Soft)
Raytraced (Hard)
Area
-(minus)
Resolution Y
Sample Radius
Sample Radius Boost:
None
Low (2x)
Medium (4x)
High (8x)
Absolute Bias
Bias (Rel)
Bias (Abs)
Parallel Width
Outline Shadow
High Quality
Shadow Cone
Angle
Soft Cone
PhotometricPhotometric Intensity-(minus)
Intensity
Unites:
Candela
Lumen
Photometric Data
Path
Photometric Size
CausticsSurface Caustics-(minus)
Noise
-(minus)
Lens
-(minus)
Project
-(minus)
SunTime-(tick)
Interpolate Time-(minus)
Interpolate Date-(minus)
Latitude-(tick)
Longitude-(tick)
Distance-(tick)
Set Light Color-(tick)
