This page provides information about the supported .vrscene features exported from Corona for Cinema 4D.
Legend
(tick) – the feature is supported
partial – only some features are supported
(minus) – the feature is exported in a vrscene but is currently not supported in Arena
(error) – the feature is not supported in Arena and currently also not exported into a vrscene
Materials
Corona Physical
UINative NameSupportNotes
metalness(tick)
base color(tick)
roughness(tick)
IOR(tick)
edge color(tick)
bumppartial
Normal maps and/or shaders work as expected when using a simple setup (Bitmap > Corona Normal > Material bump slot), however they may not work correctly in more complex scenarios (e.g. mixing two Corona Normal maps and connecting the mix with the material bump slot).
anisotropy(minus)
translucency(error)
refraction(tick)
dispersion(minus)
thin absorptionpartial
Only constant absorption is supported. Textures/shaders are not supported.
opacitypartial
Only Forced Clip mode is supported. The texture can only have fully opaque or fully transparent areas.
displacementpartial
Vantage always applies smoothing to geometry edges, similar to using mesh tessellation or subdivision.
Only single vector displacement or per-face normal displacement is exported.
In case of per-face displacement, only the lowest water level is exported.
clearcoatpartial
Clear coat bump is not supported.
sheen(minus)
volumetric absorptionpartial
volumetric scattering(error)
SSS(error)
self-illumination(tick)
background overrides(minus)
base tail(tick)
complex IOR(tick)
Corona Legacy
diffuse(tick)
translucency(error)
reflection color(tick)
fresnel IOR(tick)
reflection glossiness(tick)
reflection anisotropy(minus)
refraction color(tick)
refraction IOR(tick)
refraction glossiness(tick)
dispersion(minus)
UI
opacitypartial
bumppartial
displacementpartial
SSS(error)
Other Materials
NameSupportNotes
Corona Layered(tick)
Corona Ray Switcher(tick)Empty channels require the "Rendering of opacity maps" option enabled in Vantage. This option is enabled automatically when using the "Open scene in Vantage..." option. However, if the scene is exported to the .vrscene format and loaded or merged into Vantage, you need to enable it manually. You can find this option in Vantage under Render Settings > Advanced > Materials > Opacity maps (clip mode) or Open Render Settings button > Enable rendering of opacity maps.
Corona Shadow Catcher(error)
Corona Skin(error)
Corona Hair(error)
Corona Slicer(error)
Corona Scanned(error)
Corona Unsupported(error)
Corona Select(tick)
Bump
NameSupportNotes
Standard bumppartial
Normal map/shaderpartial
Displacement
NameSupportNotes
Normal displacementpartial
Vector displacement(minus)
Per-face normal(tick)
Per-face vector/mixed(error)
Water level(minus)
Geometry
NameSupportNotes
Triangle meshes(tick)
Hair(error)
Corona Proxy(tick)
Corona Proxy is currently exported as a regular mesh.
Corona Decalpartial
Requires Vantage 2.4.0 or newer.
Dimensions(tick)
Bendpartial
Only Bend Width is supported.
Corona Decal
Max Angle Blur
partial
There may be minor differences between the appearance of a Decal in Corona and Vantage. Specifically, the center of the Decal can be partly transparent in Corona, but it is always opaque in Vantage.
Bumppartial
Decal bump always replaces or adds to the base; the "Base only" mode is exported as "Add to base".
Displacement(error)
Displacement is always taken from the base object.
Affect Material(error)
Include/Exclude(tick)
Corona Pattern modifier(error)
Chaos Scatter(tick)
Currently scattered instanced export as individual instances. Future optimizations are planned.
VolumeGrid(error)
Lights
NameSupportNotes
Corona light (sphere, rectangle, disk)partial
Some advanced features like "prevent black appearance" do not work.
Corona light - other shapespartial
Converted as emissive mesh. It works in Vantage but is not listed in the Lights tab.
Corona light materialpartial
Non-physical lights (spot, point, etc.)(error)
Camera
NameSupportNotes
Basic perspective and orthogonal(tick)
Spherical, Cylindrical, Fisheye etc(error)
DOF(tick)
Resolution/aspect ratio(tick)
Near/far clipping(tick)
Multiple camera export(error)
Only the active camera is exported.
Environment
NameSupportNotes
Constant color environment(tick)
Textured environmentpartial
Only bitmaps, optionally with basic color correction, are supported. The current version loads with incorrect rotation in Vantage.
Physical environment (CoronaSky)partial
Sky modelspartial
The Rawa-fake model is not supported.
Clouds(tick)
Contrails(error)
Volume effect(error)
Multiple environments(error)
Corona Sun(tick)
Global volume(error)
Maps/Shaders
NameSupportNotes
TextureMappartial
Files added via the Cinema 4D Asset Browser / Database are not supported as they are not stored on the hard drive but within the Cinema 4D scene itself.
ConstantColorMap(tick)
ColorCorrectMap(tick)
DebugMappartial
Only the UVW mode and Wire color mode are supported.
CheckerMap(tick)
FrontBackMap(error)
Replaced by Mtl2Sided in export.
GradientMap(tick)
MaxFalloffMap(tick)
MixMappartial
The divide, gamma, linear light, and vivid light modes are not supported.
MultiMap (MultiShader)partial
Only some modes are supported.
MapRandomizerpartial
Only UVW randomization and only some modes are supported.
Triplanar(error)
SelectMap(tick)
NormalMappartial
Bitmappartial
Color(tick)
Filter(tick)
Checkerboard(tick)
Fresnel(tick)
Falloffpartial
Only directions aligned to +-X, +-Y or +-Z are supported.
Gradientpartial
Rotated gradient has different clamping/cycle; Some modes are not supported; Turbulence is not supported.
Fusionpartial
Layerpartial
Some modes are not supported. Most of the effects are ignored. This will be fixed in the future.
Noisepartial
Only a few of the noise types and mapping spaces are supported.
