Page Contents ×
This article explains the settings and values for the Corona Ray Switch shader.
The Corona Ray Switch is a shader that allows you to assign different shaders or solid colors for different ray types (GI, reflection, refraction, direct visibility).
Shader Properties
Global illumination – Specifies the color or texture used for global illumination rays (light reflected off this Rayswitch shader).
Reflect override – Specifies the color or texture used for reflections (the appearance of this Rayswitch shader when it is reflected in other objects).
Refract override – Specifies the color or texture used for refraction (the appearance of this Rayswitch shader when it is refracted in other objects).
Direct override – The texture map or shader loaded here is the one that is going to be directly visible.
Examples
Global illumination
None
Solid Red Color shader
Reflect override
None
Refract override
None
Direct override
None
