This page provides information on the Corona Light, its settings and usage.
Corona Light is a very flexible type of light that will let you create any light source. It can be set to area light, using either a circle or rectangle; it can be set to be an object, using a sphere, cube, or cylinder.
Corona Light objects, from the renderer point of view, do not differ from objects painted with the Corona Light Material - they are sampled the same way and have virtually the same properties.
