This page provides information about View management in Enscape.
Use the View Management button via the Enscape User Interface (UI) to manage your Views.
You can create, rename and link a View to a Visual Setting Preset in Enscape itself. Deleting Views must be done in the associated CAD you have installed Enscape for.
You can also mark a View as a Favorite View, which is designed to be used in both the Enscape Virtual Reality Presentation Mode and the Enscape Standalone Executable files.
Favorite Views will help you and your clients navigate quickly and easily to pre-selected viewpoints within your projects.
To create a Favorite View you need to have first of created a View. These Views can be either the actual 3D Views / Scenes / Named Views from the respective CAD, which can be created in the CAD itself using its own native view creation methods, or by setting up your View in the Enscape viewport and then by clicking on the Enscape Create View button which is found in the View Management panel.
Create View
Rename / Mark as Favorite
All views that you mark as a favorite will become available in the VR Presentation Mode, as well as in the right side pop-out menu in the Enscape Standalone file.
*Available only in Windows.
