©Arterra Interactive
Search
Official Release
Date - January 11, 2022
New feature
Texture
  • Support for the "auto" color space transfer function of VRayBitmap
Modified
.vantage
  • When the root .vrscene is not found with its absolute path it's searched for in the folder containing the .vantage file
Fixes
Multi GPU
  •  Line artifacts in interactive mode when using multiple GPUs
UI
  • Duplicate objects showing up in object list (with scenes from Maya)
Memory
  • Crash when out of GPU memory and the scene has a rectangle light with a texture
Tools
  • Issues in "Import changes from Vantage" MAX script:
    • Importing cameras from a .vantage file does not set the frame rate
    • Unexpected values for the "Exposure value" keys
  • Live link failing to start when "Save strings in legacy non-scene files using UTF8" is enabled in 3ds Max
.vantage
  • Error when using "Save scene settings as default"
UX
  • Undo action not working properly after a select-all(CTRL+A) action in the objects list
