©Arterra Interactive
Search
Official Release
Date - April 13, 2022
New feature
Texture
  • Partial support for V-Ray Edges texture - rounded corners are not implemented
Modified
.vantage
  • Geolocated sun animation is saved in the .vantage file
Navigation
  •  Support for mapping Chaos Vantage shortcuts through the SpaceMouse/3DConnexion controller
UX
  • 'Render setup' dialog retains settings when closed and between sessions. 'Save defaults' checkbox is removed from UI
  • Light gizmos now have consistent line width and size at different render resolution and viewport size
UI
  • Upper limit for the number of light tree samples is increased to 16
Fixes
Environment
  •  Wrong overriding of the current environment texture when using "Open Scene as Config Only..."
