This page gives details on how to borrow licenses when you're temporarily unable to access the online licensing system.
The Chaos licensing system is meant to be used online, but it includes a way to "borrow" a license for offline use for a period of up to two weeks. Borrowing a license means you can still have access to your Chaos software without the need of (stable) Internet connection. You can use your borrowed licenses for up to 14 days without an Internet connection. Their renewal happens automatically. However, the renewal process requires an Internet connection at least once in the last 3 days of the borrowing period. No additional steps are required for renewal - only an Internet connection. From the moment you renew the license, an additional 14-day borrow period begins. Therefore, if you borrowed the license on June 1st and renewed it on June 11th, you can use the offline license until June 25th.
Borrowing and releasing licenses can only be done by the license holder. If you are connected remotely to a shared Premium or Floating license, you need to ask the license holder to borrow a license for you.
Borrowing a license reserves one of your floating licenses, making it unavailable to others until you release it.
Borrowing Licenses for Machines With Internet Connection
This is the default method for borrowing a Chaos License. Follow these steps or watch the video tutorial. After successfully borrowing a license, you can disconnect from the Internet and freely use those Chaos products for up to two weeks.
Open the localhost:30304 page in a browser. It is recommended to use Google Chrome, Mozilla Firefox, or Opera browser for the localhost. Then, click on the Online licensing menu > Use licenses offline button.
Screenshot from the localhost Interface page
Click Next in the wizard to start.
Select the products you want to use. Enter the number of machines you plan to use with these products and click Preview.
Preview and adjust the precise number of licenses to borrow. Click the Borrow button to borrow the selected number of licenses.
Finally, you can see your borrowed licenses and their expiration dates. Click the Close button to return to the main menu.
Borrowing Licenses for Machines Without Internet Connection
The Chaos Licensing system is meant to be used online, but it includes the option to activate the license server and borrow licenses for a machine that does not have access to a stable internet connection.
You can borrow licenses even if the machine running the license server does not have an Internet connection. Note that you need brief access to a device with an Internet connection to activate the License Server and download the offline license certificate. This device does not need to be the same as the one running the license locally. Watch the video or follow the steps to activate and then borrow licenses on a machine without an internet connection.
Licenses can be borrowed only from an already-activated license server. When using the licenses on a machine with internet access, the licenses are automatically activated when you log in. But for machines without an internet connection, there is a separate activation process. Please first see the Activating the License Server section before you proceed with borrowing a license.
Before you can borrow a license, you need to activate your Chaos License Server. The process is slightly different than the one for machines with a (stable) Internet connection. Please follow these steps before approaching the Borrowing process.
On the machine without an Internet connection, open the localhost:30304 page in a browser. It is recommended to use Google Chrome, Mozilla Firefox, or Opera browser for the localhost. From the expandable menu of Online licensing, go to Offline activation.
Click the Activate offline button.
Download your activation request file (cert.csr) by clicking inside the gray box. When the download finishes, click Next.
Now, you will need access to a device that is connected to the Internet. Transfer the cert.csr file you just downloaded to the device with an Internet connection.
Log into my.chaos.com with the Chaos credentials associated with your License. Go to Licensing > License Servers and click Activate License Server.
Screenshot from the my.chaos page
Name your license server and upload the cert.csr file. Click Activate.
Then, the Download button appears. Click it to get your activation file (cert.crt).
Transfer the cert.crt file to the offline machine. Go to your localhost:30304 interface page and upload the activation file (cert.crt). Click Upload.
Your License Server is now successfully activated on your offline machine.
If you would like to double-check that your License Server is active, on the offline license-holder machine, go to localhost:30304 and check if the status of your Online licensing is flashing red. This means that the License Server is active, but your machine is not connected to the Internet.
Borrowing the Licenses
Borrowing licenses on a machine without a connection to the Internet requires a separate device with at least brief access to the my.chaos.com website. From there, you need to borrow the licenses and download the offline.bin file. When you upload the .bin file on the license-holder machine, your offline license is activated. Follow the steps for more information.
You cannot borrow licenses before you activate the License Server, see the Activating the License Server section before you approach this process.
On the device with an Internet connection, log into my.chaos.com with your Chaos credentials. On the License Servers tab of the page, choose a workstation from the list, for which you wish to reserve offline licenses.
Click Borrow license in the Borrowed licenses section.
Select the products you want to use. Enter the number of machines you plan to use with these products and click Next.
Click on the Download offline license file button.
On the machine that is running the license server, which cannot connect to the Internet, open localhost:30304 in a browser and click on the Online Licensing menu > Use licenses offline.
Upload the offline license .bin file and click the Upload button.
Once the file is validated, your borrowed licenses are also listed on your license server's home page.
Editing Borrowed Licenses
Online
To add new licenses, log into my.chaos.com with your Chaos credentials from a machine with an Internet connection. From the Licensing tab, go to License Servers, click on your license server, and then click Edit Borrowed Licenses.
The Edit Borrowed Licenses button only allows you to add new licenses. You cannot delete any already borrowed licenses.
If you want to increase the number of borrowed licenses, click the up arrows. If you want to borrow licenses for new products, you can use the Add more licenses dropdown menu. When you are ready, click Borrow.
Offline
If you want to change the number of borrowed licenses, you have to upload a new offline.bin file. Note that you do not need to release the licenses you already have to borrow new ones. Repeat the Offline Borrow process but change the licenses you wish to borrow with the new selection. When you upload the certificate file, the borrowed licenses will update to the new selection. See the Borrowing Licenses on the Offline Machine section for the steps.
Release Licenses
Releasing licenses is useful in a few cases. For example, when you borrow licenses on one license server instance, but actually need them on another one. Or if you need fewer borrowed licenses than the ones you currently have. Or if your borrowed licenses get stuck on the backend of a certain FLP instance due to a broken certificate.
To release a borrowed license, open the Chaos License Interface in a browser and click on the Online Licensing menu. Then click the RELEASE button to release any borrowed licenses.
To release a borrowed license before its expiration date, the machine without Internet connection needs to connect to the Internet for a brief time.
If you deactivate (sing out) your Online Licensing, the borrowed licenses will be released!
