This page outlines the product setup for using floating licenses in a local network.
What are Floating Licenses
Floating Licenses can be shared between multiple users on a first-come, first-served basis and don’t need to be assigned to an individual user.
They are are ideal for creating a pool of licenses that can be used by multiple users, who do not need to have dedicated access to our products.
Sharing can be done in one of two ways:
- Cloud-Based Floating Licensing (recommended): The administrator shares a pool of Floating licenses with the Organization's Users, and when they log in with their Chaos accounts, they can use the floating licenses through the cloud from any location. See the Cloud-Based Floating Licensing page for more details.
- Remote Licensing: The administrator installs the Chaos License Server on a centrally accessible machine within a local network. The users will need to configure their Chaos product to connect to this centralized network location to access a license. Read below for details on this setup.
Floating Licensing Setup for a Local Network
- When setting up floating licenses in a local network, the Chaos License Server needs to be installed on a centrally accessible machine in the network.
- The License Server needs to be authenticated with a Chaos account that holds the floating license pool. This is usually the Administrator's account.
- The Administrator shares the IP address of the machine where the Chaos License Server is installed
- Users configure their Chaos products to connect to the Chaos License Server on the local network.
- Ask your license holder for their machine's IP address.
- Download your Chaos product(s) and run the installer. After accepting the End User License Agreement, select the Advanced installation option.
Example screenshot
- At the Licensing screen, select Remote. In the Primary License Server field, type the server IP address provided by your license administrator. At the end, add the :30304 port.
- Continue to finish the installation and start using your Chaos product.
Example screenshot
Re-configuring your License
If you have upgraded your Chaos License plan, or if you misconfigured your license settings, here is how you can re-configure your Chaos license setup:
One option is to use the change your Chaos product's license setup. See the Changing the Product License Setup page for mode details.
Alternatively, you can re-install your current Chaos product and repeat the steps from this page.
