This page provides information on the silent install and uninstall processes for Chaos Phoenix.
A silent installation performs a Phoenix installation without user input during the process. A predefined set of options is used. A silent uninstallation will uninstall Phoenix using a similar method.
By using the Chaos installer for automatic installation with the respective options for that (-auto or -quiet=1), or otherwise installing a Chaos product, you accept the Chaos End User License Agreement and the Chaos Global Consumer Privacy Policy.
Silent Install
To set up a silent installation, you need to perform several steps:
1. First, you need to generate a template configuration file. This is automatically done by running the installer from the command line like this:
phoenixFD_adv_30502_max2015_vray_30_x64.exe -gui=0
You can also add the -auto flag to make the installation automatic with default settings. Note that this accepts both the EULA and the Privacy Policy.
2. The installation should start in console mode, and you must manually input all the necessary fields (install directory, license method, etc). The installer will ask you for everything important. After the installation is complete, a configuration XML file named config.xml is generated in the directory of the installer. Afterwards, you can easily perform the installation again or on another machine (using the same configuration) by the command line:
phoenixFD_adv_30502_max2015_vray_30_x64.exe -configFile="config.xml"
Here's a sample config.xml file generated by the installer:
<DefValues>
 <Value Name="SHOULDUNINSTALL" DataType="value">1</Value>
 <Value Name="STD_ROOT" DataType="value">NOT_INSTALLED</Value>
 <Value Name="SCENES" DataType="value">C:\Program Files\Autodesk\3ds Max 2015\scenes\PhoenixFD\</Value>
 <Value Name="REMOTE_LICENSE" DataType="value">1</Value>
 <Value Name="VROL_INSTALLED" DataType="value">0</Value>
 <Value Name="VROL_INSTALL_PATH" DataType="value">not_installed</Value>
 <Value Name="ISRUNNING_VROL" DataType="value">0</Value>
 <Value Name="ISRUNNING_VRLSERVICE" DataType="value">0</Value>
 <Value Name="REVERT_INSTALL" DataType="value">1</Value>
 <Value Name="PROGRAMFILES" DataType="value">C:\Program Files</Value>
 <Value Name="MAXROOT" DataType="value">C:\Program Files\Autodesk\3ds Max 2015\</Value>
 <Value Name="PHXROOT" DataType="value">C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2015 for x64</Value>
 <Value Name="RTROOT" DataType="value">C:\Program Files\Chaos Group\V-Ray\RT for 3ds Max 2015 for x64</Value>
 <Value Name="PLUGINS" DataType="value">C:\Program Files\Autodesk\3ds Max 2015\plugins</Value>
 <Value Name="STARTMENUPROG" DataType="value">C:\ProgramData\Microsoft\Windows\Start Menu\Programs</Value>
 <Value Name="COMMONFILES" DataType="value">C:\Program Files\Common Files</Value>
 <Value Name="VISIT_DOCS" DataType="value">0</Value>
 <Value Name="OPEN_CHANGELOG" DataType="value">0</Value>
 <Value Name="INSTALL_TYPE" DataType="value">0</Value>
 <LicServer>
  <Host>10.0.0.255</Host>
  <Port>12345</Port>
  <Host1></Host1>
  <Port1>12345</Port1>
  <Host2></Host2>
  <Port2>12345</Port2>
  <User></User>
 </LicServer>
</DefValues>
3. You may also use a .bat file to run this command directly from the Explorer. This will start the installer with almost no output. If you want the output, you can add the argument -quiet=0 to the command. To save the output in a file, you can use the normal command line pipeline. To perform an installation with an output to a file, call the installer with the following:
phoenixFD_adv_30502_max2015_vray_30_x64.exe -configFile="config.xml" -quiet=0 > output.txt
You can append to the file (rather than replacing its contents) by using '>>' instead of '>' for the pipe.
3.1. Also, there is an easier way to install with default settings (default folder, etc) by issuing the following command:
The output can be controlled by -quiet=1 or -quiet=0.
Below is a description of the variables of the installer's xml:
MAXROOT
 Specifies the root 3ds Max folder.
PLUGINS
 Specifies the plugins folder for 3ds Max; the default places it as a sub-folder of the 3ds Max root one.
OPEN_README
Specifies whether or not to open the Read Me once the installation is complete.1 opens the Read Me file.0 does not open the Read me file.
OPEN_CHANGELOG
Specifies whether or not to open the Change Log once the installation is complete1 opens the Change Log.0 does not open the Change Log.
INSTALL_WIBU
Specifies whether or not the WIBU-KEY drivers will be installed.1 starts the WIBU-KEY drivers installation.0 skips the WIBU-KEY drivers installation.
REG_LIC_SERVER
Specifies whether or not to register the Phoenix License Service.1 registers the Phoenix License Service.0 does not register the Phoenix License Service.This variable is only valid when the installation is set to either Workstation or License server
REMOTE_LICENSE
Specifies whether the Phoenix license server runs locally or on another machine.0 - the license server runs locally on the same machine.1 - the server is on a different machine in the network.If this variable is 1, the license server itself will not be installed. To configure the license server settings, you will need to run the "setvrlservice" program after the installation. Normally it is located in "C:\Program Files\Chaos Group\Phoenix FD\3dsmax xxx for x64\setvrlservice.exe". The license server is specified using "-server" option, for example: "C:\Program Files\Chaos Group\Phoenix FD\3dsmax xxxx for x64\setvrlservice.exe" -server=10.10.10.11Set the VRAY_AUTH_CLIENT_FILE_PATH environment variable to point to the folder that contains the vrlclient.xml file with the Phoenix FD license server settings (IP address and port number).
STD_ROOT
Specifies the destination folder for Phoenix additional files (documents, SDK, and uninstall information).
RTROOT
Specifies the destination folder for V-Ray RT files. This is only available in the V-Ray version of Phoenix.
SHOULDUNINSTALL
Specifies whether or not the installation will uninstall previous version:1 uninstalls previous version;0 skips the uninstallation of previous version.
Silent Uninstall
You can also use a command to perform a silent uninstall. To do this, you need to know the full path of the folder containing Phoenix's additional files and the exact name of the product you want to uninstall. Then you can execute the following command:
"<STD_ROOT>\uninstall\installer.exe" -uninstall="<STD_ROOT>/uninstall/install.log" -uninstallApp="<PRODUCT_NAME>" -gui=0 -quiet=1
where <STD_ROOT> is the destination folder and <PRODUCT_NAME> is the product name i.e. “Phoenix FD for 3ds Max 2015 for x64”
For example, the following command will uninstall Phoenix for 3ds Max 2015:
"C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2015 for x64\uninstall\installer.exe" -uninstall="C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2015 for x64\uninstall\install.log" -uninstallApp="Phoenix FD for 3ds Max 2015 for x64"
