This page provides information on setting up Phoenix so that it can run from a location different from the default.
Installing Phoenix for Maya from an unpacked installation provides several advantages over the regular installer:
- The unpacked installation allows for setting a custom environment when starting each Maya instance. In comparison, running the regular installation multiple times overwrites the Phoenix environment variables.
- The unpacked installation can be used to run Phoenix for Maya from any location or even a network drive. That way, multiple users can start Maya along with Phoenix using just a script that sets up the environment variables without the need to run local installations.
- Upgrading an unpacked installation is a lot easier too, as you don't need to run the installer on every user's computer.
- The unpacked installation allows for quick switching between different Phoenix versions without reinstalling it.
When using an unpacked installation of Phoenix, the EULA needs to be accepted to start a simulation. A pop-up window appears when the simulation begins.
Required steps to run Phoenix
Here is an overview of the steps required to run an unpacked installation:
- Unpack the installer file to a location of your choice.
- Set up the environment variables needed to run Phoenix for Maya.
- Set up your license. For more information on licensing check this page.
- Run Maya.
It is highly recommended to only use Phoenix from an unpacked installation or from a regular installation, but never both at the same time. If you plan on using the unpacked installation, make sure to uninstall Phoenix beforehand.
Unpacking the installer file
In order to extract the contents of the installer file into a suitable folder you need to unpack them first.
You can unpack the installation files in two ways - using the GUI installer or through the command line.
Setting up the installation files using the GUI installer
Running Phoenix for Maya from a network location has two parts to it. First, you must run the installation to extract the necessary files and store them on the network. Next, you must configure your local machine to use these files to run Phoenix for Maya, or to run V-Ray Standalone with Phoenix support.
Phoenix does not require a V-Ray for Maya installation to load and work correctly inside Maya.
Run the Phoenix for Maya installation and specify suitable folders for the files. For example, you could create a network shared path named /phoenix_builds/my_version, where you could change my_version to the Phoenix version you are using in order to allow multiple different versions. Then in the Phoenix installer's Advanced step, you could direct the installation to the following paths:
Maya root folder: /phoenix_builds/my_version/maya_root
Maya plugins destination folder: /phoenix_builds/my_version/maya_phoenix
Chaos Phoenix additional files: /phoenix_builds/my_version/phoenix
Setting up the installation Files using the command line
Windows/Linux:
- Navigate to the installer in a Command prompt/Terminal.
- Add the argument -unpackInstall=<directory_to_unpack> (the location of the folder you want your install to be unpacked in).
Example:
"D:/Downloads/phoenixFD_adv_50000_maya2023_vray6_x64.exe" -unpackInstall="D:/unpacked_installation"
macOS:
- Download the installer and extract the .app from the .dmg.
- In the Terminal navigate inside the .app to /Contents/MacOS/run_installer.
You can also do the following for all OS:
- In a Command Prompt/Terminal change the directory to the folder where you want to unpack the installation.
- Navigate to the installer and add the argument -unpackInstall.
Example:
"/Desktop/phoenixFD_adv_50000_maya2023_vray6_x64.app/Contents/MacOS/run_installer" -unpackInstall=/phoenix_builds/phoenixFD_adv_50000_maya2023_vray6_x64
Setting up Environment variables
Before you run Maya, you need to set the following environmental variables on the local machine.
The example directory and version names below are for Phoenix 5 for Maya 2023 for V-Ray 7 on Windows where phoenixFD_adv_52300_maya2023_vray7_x64.exe has been unpacked into D:\phoenix_builds\my_version\.
Here is a list of the environment variables and examples.
OS | Action | Variable | Location | Example |
Windows | Set | PHX_FOR_MAYANNNN_MAIN | <unpacked_install_location>/maya_phoenix | set PHX_FOR_MAYA2023_MAIN=D:\phoenix_builds\my_version\maya_phoenix |
Windows | Set | PHX_FOR_MAYANNNN_BIN | <unpacked_install_location>/phoenix/bin | set PHX_FOR_MAYA2023_BIN=D:\phoenix_builds\my_version\phoenix\bin |
Windows | Set | PHX_FOR_MAYANNNN_STNDPLUGS | <unpacked_install_location>/phoenix/bin/plugins | set PHX_FOR_MAYA2023_STNDPLUGS=D:\phoenix_builds\my_version\phoenix\bin\plugins |
Windows | Extend | MAYA_PLUG_IN_PATH | <unpacked_install_location>/maya_phoenix/plug-ins | set MAYA_PLUG_IN_PATH=D:\phoenix_builds\my_version\maya_phoenix\plug-ins;%MAYA_PLUG_IN_PATH% |
Windows | Extend | MAYA_SCRIPT_PATH | <unpacked_install_location>/maya_phoenix/scripts | set MAYA_SCRIPT_PATH=D:\phoenix_builds\my_version\maya_phoenix\scripts;%MAYA_SCRIPT_PATH% |
Windows | Extend | XBMLANGPATH | <unpacked_install_location>/maya_phoenix/icons | set XBMLANGPATH=D:\phoenix_builds\my_version\maya_phoenix\icons;%XBMLANGPATH% |
Windows | Extend | VRAY_FOR_MAYANNNN_PLUGINS1 | <unpacked_install_location>/phoenix/vray7plugins | set VRAY_FOR_MAYA2023_PLUGINS=D:\phoenix_builds\my_version\phoenix\vray7plugins;%VRAY_FOR_MAYA2023_PLUGINS% |
The example directory and version names below are for Phoenix 5 for Maya 2023 for V-Ray 7 on Linux where phoenixFD_adv_52300_maya2023_vray7_x64 has been unpacked into /phoenix_builds/my_version/.
Linux | Set | PHX_FOR_MAYANNNN_MAIN | <unpacked_install_location>/maya_phoenix | export PHX_FOR_MAYA2023_MAIN=/phoenix_builds/my_version/maya_phoenix |
Linux | Set | PHX_FOR_MAYANNNN_BIN | <unpacked_install_location>/phoenix/bin | export PHX_FOR_MAYA2023_BIN=/phoenix_builds/my_version/phoenix/bin |
Linux | Set | PHX_FOR_MAYANNNN_STNDPLUGS | <unpacked_install_location>/phoenix/bin/plugins | export PHX_FOR_MAYA2023_STNDPLUGS=/phoenix_builds/my_version/phoenix/bin/plugins |
Linux | Extend | MAYA_PLUG_IN_PATH | <unpacked_install_location>/maya_phoenix/plug-ins | export MAYA_PLUG_IN_PATH=/phoenix_builds/my_version/maya_phoenix/plug-ins:$MAYA_PLUG_IN_PATH |
Linux | Extend | MAYA_SCRIPT_PATH | <unpacked_install_location>/maya_phoenix/scripts | export MAYA_SCRIPT_PATH=/phoenix_builds/my_version/maya_phoenix/scripts:$MAYA_SCRIPT_PATH |
Linux | Extend | XBMLANGPATH | <unpacked_install_location>/maya_phoenix/icons | export XBMLANGPATH=/phoenix_builds/my_version/maya_phoenix/icons/%B:$XBMLANGPATH |
Linux | Extend | VRAY_FOR_MAYANNNN_PLUGINS1 | <unpacked_install_location>/phoenix/vray7plugins | export VRAY_FOR_MAYA2023_PLUGINS=/phoenix_builds/my_version/phoenix/vray7plugins:$VRAY_FOR_MAYA2023_PLUGINS |
The example directory and version names below are for Phoenix 5 for Maya 2023 for V-Ray 7 on macOS where phoenixFD_adv_52300_maya2023_vray7_x64 has been unpacked into /phoenix_builds/my_version/.
macOS | Set | PHX_FOR_MAYANNNN_MAIN | <unpacked_install_location>/maya_phoenix | export PHX_FOR_MAYA2023_MAIN=/phoenix_builds/my_version/maya_phoenix |
macOS | Set | PHX_FOR_MAYANNNN_BIN | <unpacked_install_location>/ChaosPhoenix.app/Contents/MacOS | export PHX_FOR_MAYA2023_BIN=/phoenix_builds/my_version/ChaosPhoenix.app/Contents/MacOS |
macOS | Set | PHX_FOR_MAYANNNN_STNDPLUGS | <unpacked_install_location>ChaosPhoenix.app/Contents/MacOS/plugins | export PHX_FOR_MAYA2023_STNDPLUGS=/phoenix_builds/my_version/ChaosPhoenix.app/Contents/MacOS/plugins |
macOS | Extend | MAYA_PLUG_IN_PATH | <unpacked_install_location>/maya_phoenix/plug-ins | export MAYA_PLUG_IN_PATH=/phoenix_builds/my_version/maya_phoenix/plug-ins:$MAYA_PLUG_IN_PATH |
macOS | Extend | MAYA_SCRIPT_PATH | <unpacked_install_location>/maya_phoenix/scripts | export MAYA_SCRIPT_PATH=/phoenix_builds/my_version/maya_phoenix/scripts:$MAYA_SCRIPT_PATH |
macOS | Extend | XBMLANGPATH | <unpacked_install_location>/maya_phoenix/icons | export XBMLANGPATH=/phoenix_builds/my_version/maya_phoenix/icons:$XBMLANGPATH |
macOS | Extend | VRAY_FOR_MAYANNNN_PLUGINS1 | <unpacked_install_location>/phoenix/vray7plugins | export VRAY_FOR_MAYA2023_PLUGINS=/phoenix_builds/my_version/ChaosPhoenix.app/Contents/MacOS/vray7plugins:$VRAY_FOR_MAYA2023_PLUGINS |
Notes:
1 - Alternatively if you are rendering with V-Ray Standalone 7 or newer (meaning you render vrscenes or render using V-Ray GPU), you can copy all files inside the /phoenix_builds/my_version/phoenix/vray7plugins folder to the folder that the VRAY_FOR_MAYANNNN_PLUGINS environment variable points to (specified during the V-Ray for Maya installation). This would affect only this specific V-Ray Standalone version
or
append the /phoenix_builds/my_version/phoenix/vray7plugins path to the VRAY_PLUGINS environment variable. Note that this would affect all installed V-Ray versions.
For V-Ray versions older than V-Ray 6 copy all files from /phoenix_builds/my_version/phoenix/vray5plugins folder to the folder that the VRAY_FOR_MAYANNNN_PLUGINS environment variable points to (specified during the V-Ray for Maya installation). This would affect only this specific V-Ray Standalone version
or
append the /phoenix_builds/my_version/phoenix/vray5plugins path to the VRAY_PLUGINS environment variable. Note that this would affect all installed V-Ray versions.
Updating the installation to a newer version of Phoenix
You need an unpacked installation of Phoenix which you would extract directly into the network shared folder. E.g. if your network path is named /phoenix_builds/my_version, you should extract the Phoenix unpacked install in that folder and allow it to overwrite all files. This is all that is needed to update the Phoenix network shared installation.
