This page provides information on Pdplayer's integration with Autodesk Maya.
Pdplayer can very easily be integrated with Autodesk Maya to view single images or sequences.
Integration
Open the Preferences dialog in Maya and in the Applications Category choose Chaos Player to be used as the default software for viewing images and sequences. You should also put "%f --fcheck --range=%s-%e/%b --fps=%r%" in each Optional Flags field in order to specify the file name.
For "Sequence Viewing Applications" you can add the --play_forward flag so that Chaos Player automatically starts the playback. Option flags example: "%f --fcheck --range=%s-%e/%b --fps=%r% --play_forward".
Integration with Autodesk Maya
