This page provides information about the Color To Float utility texture in the V-Ray Node Editor in Blender.
The Color To Float node converts a color or texture into a floating point value.
This node has no controllable parameters.
UI Path: ||V-Ray Node Editor|| > Shader > Add > Texture Utilities > V-Ray Color To Float
UI Path: ||V-Ray Node Editor|| > Object > Add > Texture Utilities > V-Ray Color To Float
UI Path: ||V-Ray Node Editor|| > World > Add > Texture Utilities > V-Ray Color To Float
Node Input Sockets
Input – Allows you to connect a color node to this texture. Otherwise, a custom solid color can be defined.
Example setup
