This page provides information about the Color Range node in V-Ray for Cinema 4D.
The Color Range node remaps textures from some old range to a new range of values. The ranges can be mapped with other nodes.
Value – The input color or texture node.
Input Min – Specifies the lower range or the minimum value for the input map.
Input Max – Specifies the higher threshold or the maximum value for the input map.
Output Min – Specifies the minimum value for the output map.
Output Max Specifies the maximum value for the output map.
