©BBB3viz
This page provides information on V-Ray compatibility with G-Buffer output.
V-Ray supports multi-layered G-Buffer output required for writing .rla and .rpf files, as well as by many 3ds Max render effects. V-Ray automatically generates the G-buffer channels requested by the image output and the render effects so there is no need to select these manually.
Supported G-Buffer Channels
This is a list of supported G-Buffer channels in 3ds Max.
3ds Max Channel Name
Supported by V-Ray
Description
Z
YES
Depth buffer (distance to the camera XY plane).
Material Effects
YES
The material ID.
Object
YES
The object node ID that is set through the Properties dialog of an object.
UV Coordinates
YES
The surface UV coordinates. V-Ray always outputs the UV coordinates for mapping channel 1.
Normal
YES
The surface normal relative to the camera.
Non-Clamped Color
YES
The real unclamped pixel color, before any color mapping is applied to the pixels. Like with the scanline renderer, this channel does not store atmospheric effects.
Coverage
YES
The contribution of an object to the image pixel.
Node Render ID
YES
A unique ID assigned to each node by the renderer.
Color
YES
The material color for the object. Like with the scanline renderer, this does not include any atmospheric effects.
Transparency
YES
The material transparency for the object. Like with the scanline renderer, this does not include atmospherics.
Velocity
YES
The surface velocity relative to the camera.
Sub-Pixel Weight
YES
The contribution of an object to the image pixel including transparencies.
Sub-Pixel Mask
NO
A bit mask for the contribution of an object to a pixel. The Sub-Pixel Mask channel is meaningless when AA filters, depth of field, and motion blur are taken into consideration, which is why V-Ray does not support it.
  • V-Ray takes antialiasing filters into account when generating the G-buffer channels, in contrast with the default scanline renderer of 3ds Max. This may cause differences in the way some render effects work. If this is a problem, turn off the AA filter from the Image sampler rollout. Also, avoid using AA filters with negative components (Catmull-RomMitchell-Netravali) when generating a G-buffer; 3ds Max cannot handle layers with negative coverage and V-Ray ignores those when creating the 3ds Max G-buffer.
  • Generating a correct multi-layer G-buffer requires extra memory. This is because the 3ds Max G-buffer only supports scanline-style writing. However, V-Ray renders in buckets and cannot provide the data in scanline order. To work around this, V-Ray stores all the G-buffer data while rendering and then writes it at once into the final image.
  • G-Buffer layers are now generated correctly in distributed rendering mode. This means that render effects like image motion blur now work in DR mode too.
