Page Contents ×
This page provides information about Light Path Expressions.
Light Path Expressions or LPEs are a very powerful and advanced tool for extracting specific lighting events from the scene to a separate channel. This allows for a very fine control of the image in compositing. For example, LPEs allow capturing only self-reflections, or the 1st bounce of GI, or the SSS that's only seen behind glass and similar for compositing control of only this aspect of the image.
The LPE syntax is based on regular expressions. Expressions describe a light path that starts from the camera and bounces around the scene until it reaches a light source.
The scene setup is similar to the Light Select workflow. As LPEs are a mode of the Light Select, the expression will capture contributions of the light that is added to the Light Select set. If the Light Select is empty, the expression will extract contributions from all scene lights. LPEs also allow extracting information from the environment, for example allow capturing the GI that comes from the environment only.
We’ve added a list of the basic symbols for constructing a Light Path expression.
Тhere is a dedicated LPE Builder available to help you compose expressions and track exactly which ray paths they capture.
Additionally, you can see what expression should get you the equivalent of some of the already available render elements (like Beauty, Lighting, GI, Light Select types etc.).
It is faster and more efficient to use the already available render elements instead of their LPE equivalents in the presets, of course - the examples are there as a point of reference.
Finally, there's some Misc and masking LPE examples, e.g. to capture the GI coming from the environment or to get the GI coming from a given light bounced off of a given object marked by an extra attribute.
LPE Symbols
The LPE alphabet consists of the symbols representing a ray event/type and additional regular expression symbols (“.”, “+”, “*”, “<”, “>”, “[“, “]”, “|”, “?”, “^” and additional label strings).
A valid expression needs to start from the camera (C), capture ray spawn or scattering events and end at light (L), emissive object (O) or the environment (B).
Ray spawn events other than C can be combined with scattering types (e.g. <RD> - capture only diffuse reflection) to get a more specific ray event or they can be used directly (e.g. R - capture reflections of any scattering type. This is also equivalent to <R.>)
Ray termination events can also be combined with each other when you want to capture the contribution of a light together with emissive objects, e.g. C<RD>.*[LO] will capture the GI coming from lights or emissive objects.
Symbol
Description
Type
Final
Initial ray spawn event
C
Camera ray
No
Ray spawn events
R
Reflection ray
Ray spawn event
No
T
Transmission ray
Ray spawn event
No
V
Volume ray
Ray spawn event
No
Scattering types
D
Diffuse scattering
Scattering type
No
G
Glossy scattering
Scattering type
No
S
Singular scattering
Scattering type
No
s
Straight (no) scattering
Scattering type
No
L
Light hit
Ray intersection event
Yes
O
Emitting object hit
Yes
B
Background hit
Yes
Render Elements
Preset
Light path expression
Render elements
RGBC.*
Self-illuminationC[OL]
BackgroundCB
LightingC<RD>L
SpecularC<R[GS]>L
GIC<RD>(.+L|.*[OB])
SSSC<TD>.+L
ReflectionC<R[GS]>.+L
RefractionC<T[GS]>.+L
AtmosphereCV.*
Light Select
Preset
Light selects
Direct IlluminationCRL
Direct DiffuseC<RD>L
Direct SpecularC<R[GS]>L
FullC.*L
IndirectCR.+L
Indirect DiffuseC<RD>.+L
Indirect SpecularC<R[GS]>.+L
Misc
Preset
Misc
Self-illumination, no lights
CO
GI from self-illuminationC<RD>.*O
GI from environmentC<RD>.*B
Object/material select
Preset
Object/Material select
Indirect for the object label "obj1"
CR'obj1'.+L
Indirect for all object labels but "obj1" and "obj2"CR[^'obj1''obj2'].+L
RGB for material "Material #01"C.'mMaterial #01'.*
In order to use Object select, an object label can be set in the LPE label field in V-Ray Object Properties window. When Material select is used, materials names are used as labels.
