© Taichi Kobayashi
Date – August 09, 2018
DownloadBuild 4.03.03
Key Features
GPU Rendering
  • V-Ray for Houdini comes bundled with the same GPU rendering improvements implemented in the other V-Ray Next DCC integrations.
Volume Rendering
  • Support for VDB rendering through the Volume Grid Cache SOP and the Volume Grid Shader VOP.
  • Support for direct rendering of volumetrics without the process of loading the files through a Volume Grid Cache SOP is coming in the future. A major advantage of V-Ray vs competitive products is the fast computation of volumetric lighting, ie. fire illuminating the smoke and fire illuminating the scene.
VRScene Rendering
  • Instancing of VRScenes with custom transformations and orientation is fully supported, allowing the user to easily transfer assets in a V-Ray based pipeline.
  • Custom overrides on the imported VRScene are fully supported. Geometry in the VRScene is represented as Primitive Groups, allowing you to override the material assignments on a per-object basis.
Alembic support
  • Тargeting of individual objects in the packed alembic hierarchy for material assignment is fully supported. Transformations, copying, instancing, etc. are supported.
Hair & Fur
  • Rendering of Houdini hair generated at the SOP level is fully supported. V-Ray for Houdini comes with the new Hair 4 shader.
Particles
  • Driving the shader parameters through custom attributes on a per-point basis is supported.
Packed Primitives
  • Тargeting of primitives in the packed object hierarchy for material assignment is fully supported.
  • Rendering of Packed Fragments and Agents for Rigid Body and Crowd simulations is supported.
Material Stylesheets
  • Full support for material overrides based on groups, bundles, attributes, etc.
Instancing
  • Copying of Packed Geometry, Instancer and “instancepath” attribute works with all supported object types, including Volumes.
  • Instancing of lights is supported, with options for per-instance overrides of the light parameters.
Other Features
Object Types
  • Regular Polygon Geometry as GeomStaticMesh
  • Regular Poly Soup Geometry as GeomStaticMesh
  • Packed Geometry
  • Poly Lines as GeomMayaHair
  • Curves (NURBS, Bezier) as GeomMayaHair
  • Points as GeomParticleSystem
  • Instanced Geometry
  • VRayProxy loaded through VRProxy SOP node
  • VRayScene loaded through VRScene SOP node
  • Volumes as VDBs loaded through Volume Grid Cache SOP node
  • V-Ray Infinite Plane
  • Subdivision and Displacement
  • Node linking through op:/path syntax
Lights
  • Support for Houdini’s Light Linker
  • Ambient, Direct, Dome, IES, Mesh, Omni, Rectangle, Sphere, Spot, Sun
  • V-Ray Sky as Environment or Dome Light texture
  • Light Instancing through instancepath attribute or Houdini Instancer - support for color and intensity per-instance overrides and Light Linker overrides (per base object)
Camera
  • V-Ray Physical Camera -- Aperture, Focal Length and F-Stop inherited from Houdini’s camera settings so the camera manipulator handles can be used.
  • Spherical, Cylindrical, Box, Fish-Eye, Warped, Ortho, Pinhole, Spherical, Cubic projection
  • Depth of Field and Motion Blur supported
Animated Geometry
  • Full support for transofrmations
  • Full support for deformations.
Instancing Types
  • Instancing through Instance node
  • Light Instancing through Instance node
  • Instancing through instancepath attribute
  • Instancing of volumetrics supported
Simulation Types
  • Particle Simulations
  • PBD Grain Simulations
  • Crowd Simulations
  • Cloth Simulations
  • RBD Simulations
  • Volumetric rendering of VDBs with Volume Grid Cache -> Volume Grid Shader
  • FLIP simulation rendering of meshed surfac
  •  FLIP secondary effects (Foam, Bubbles, etc) as particles or VDBs
Import/Export
  • Proxy Import/Export
  • VRScene Import/Export
  • Alembic - Full Support
  • Houdini bgeo - Full Support
  • Yeti caches through VRayPgYeti SOP
Stylesheets
  • Limited support of VEX
  • String overrides not yet implemented per polygon
  • Full support for overrides based on primitive attributes, groups, bundles, etc
  • Support for Global Stylesheets
  • No support for per ROP stylesheets akin to Mantra ROP -> Decale Style Sheets / Apply Style Sheets parameter yet.
IPR
  • Limited GPU update support
