This page provides information on the VRayPlane node.
The VRayPlane is a very simple function that creates a procedural infinite-plane primitive for V-Ray.
UI Path: ||Toolbar|| > V-Ray Menu icon > Geometry > VRayPlane
Inputs
The following parameters can be controlled by inputs.
img – An optional input to load a bitmap or VRayMtl that will be applied to the plane.
display – Specifies how the VRayPlane appears in the 3D viewer. The viewer can override this setting.
off
wireframe
solid
solid + wireframe
textured
textured + wireframe
unchanged
selectable – Enables the VRayPlane to be selectable in the viewer.
The position of the plane depends on its transformation in the scene.
You can have more than one infinite plane in the scene.
The plane is rendered with the material applied to the VRayPlane object.
