This page provides a detailed QuickStart guide to using V-Ray lights in Nuke.
In this tutorial we are going take a look at the V-Ray lights in V-Ray for Nuke. In the Lights menu are are several options, which we explore in this tutorial:
VRayLightAmbient, which contributes a solid-colored light to scene
VRayLightDome, which creates a global illumination image based light
VRayLightIES uses common light IES files to describe light’s falloffs and intensities
VRayLightMesh turns any geometry into a light source including animated geometry
VRayLightRect, a simple light source and the most commonly used
VRayLightSpehere, a simple point light source
To follow this tutorial, you will need to have the V-Ray for Nuke plugin installed. This tutorial is a companion to go along with the QuickStart video posted on our YouTube channel.
Tutorial Assets
To download the files used in this tutorial, please click on the button below.
Due to licensing issues, the Road_A.hdr file used in the tutorial video is not included in the downloadable assets. Instead, please use one of the provided HDR images in its place.
Tutorial Steps
1) Adjusting the VRayLightDome
Starting Scene Layout
Open the finished scene from the tutorial QuickStart 3 on texture mapping. Change the Focal Length of the VRayCamera to 21 so you can see more of the scene.
The scene is currently lit by a VRayLightDome with its properties set to use only the upper half of the hemisphere and its visibility set to Invisible. This gave us a darker lighting underneath.
Enable the Dome Spherical checkbox to make the VRayLightDome a sphere. You now have a full sphere with the HDR texture lighting the geometry and filling in these areas with light. Disable the Invisible checkbox so the HDR is visible as a texture on the VRayLightDome. The HDR is now both above and below the geometry, and wraps around it as a full sphere.
Focal length properties
eVRayCamera translate and rotate values
Change the camera angle by clicking the VRayCamera and changing the x rotate value under the Camera tab of the VRayCamera properties from -35 to -15. Now you can see the horizon on the HDR. To see this in the render, disable the Dome Spherical checkbox so that the VRayLightDome is a hemisphere.
Enable the Dome Spherical checkbox again, and reposition the x rotate value back to -35. Disconnect this light from the scene for now and move it to one side so it doesn’t get in the way.
VRayLightDome with Dome Spherical checked
2) Adding a VRayLightRect
Add a VRayLightRect to the Nuke script and create a new scene named Lights. Connect the Lights scene to the main scene and the VRayLightRect to the Lights scene so that the VRayLightRect is now the only light lighting the geometry. Switch to the 3D view and move this light up above the geometry. Enter -90 for the rotate x value under the Axis tab.
You’ll notice that the light isn’t illuminating things at all at this stage. The brightness level can be changed by either increasing the light’s Intensity value or by adjusting the scale for the VRayLightRect. In this case we have a very large scene, so it makes more sense to increase the uniform scale value under the Axis tab. Change the uniform scale value to 1000. Now you should be able to see the VRayLightRect lighting the geometry from above.
VRayLightRect properties
VRayLightRect position and rotate values
VRayLightRect2 position and rotation
Duplicate the VRayLightRect and connect this new light into the Lights scene. Right now this new light has exactly the same position and intensity as the version you copied it from. You are going to change this so that the new light illuminates the geometry from the side. First, press Pause on the interface to stop Nuke from updating the render in the viewer while you work on the VRayLightRect settings. Grab the new VRayLightRect, move it to the right in the 3D view, and pull it downwards in the Z axis so it’s level with the geometry as shown:
Under the Axis tab, change the rotate values to 0, -90, and 0 for x, y, and z respectively. To make this light less intense and not as strong as the first VRayLightRect, change its Intensity value to 5. Let’s change the color produced by this light by clicking on the color wheel button and changing the color to a warm red color. It’s a good idea to disable the other VRayLightRect (by hovering over it and pressing the D key) so we can see exactly how the second light is affecting the scene while we make any tweaks or changes to its color. We are aiming for a warm color as shown, without it being too saturated.
VRayLightRect2 light color settings
3) Adding a VRayLightAmbient
Add a VRayLightAmbient into the Nuke script and connect it to the Lights scene. This will act as the fill light. You could use the VRayLightDome as a fill light, but first let’s look at how to use VRayLightAmbient as the fill.
You will notice that this light’s default intensity is very strong and flattens out the lighting. Change its Intensity value to 0.01. This lights the dark areas in the render so that you don’t have total blackness in those parts of the image. At this low intensity, the effect is very subtle.
VRayLightAmbient properties
VRayLightAmbient position
If you change the connection over from the VRayLightAmbient to the VRayLightDome (with the HDR connected to its tex slot) you can compare how the fill lighting compares. If you drag and select each VRayLightRect and enable and disable it, you can see how each of those lights affect the scene.
Scene Layout so far
4) Adding a VRayLightSphere
Add a VRayLightSphere (a point source light) into the Nuke script and connect it to the Lights scene. Disable all the other lights in the Nuke script so you can work on setting up the VRayLightSphere on its own. In the 3D view, move this light over to the right a little. As this is a large scene, we will need to scale up the light by changing the uniform scale value to 100.
VRayLightSphere visible in the render
You will now be able to see the VRayLightSphere lighting the geometry, but you can also see the light itself in the render. Under the Options section for the VRayLightSphere, enable the Invisible checkbox. You will notice that although the light is still lighting the geometry, it is no longer visible in the render.
VRayLightSphere now invisible in the render
The layout of the Nuke script so far
5) Adding a VRayLightIES
Let’s next take a look at the VRayLightIES by adding it to the Nuke script and connecting it to the Lights scene. Ensure that for now the VRayLightSphere and all other lights are disabled so that you can only see the lighting contribution made by the VRayLightIES.
An IES file is a descriptor of a real world light. In the properties for this light, browse for the Overhead.IES file so it is used to illuminate the scene.
VRayLightIES properties
Move this light up above the geometry change its uniform scale value to 1000. You can tell which way it is pointing by looking at the circle on the shape that represents the VRayLightIES. As you can see, it’s currently not pointing at the geometry. Change its rotate x value under the Axis tab to -90 to make the light point at the geometry.
VRayLightIES position
Once again you should now have the light pointing at the geometry from the top, which you will now be able to see in the render.
The VRayLightIES’s position in the 3D viewport
Now that you can see the VRayLightIES’s lighting contribution to the render, we can turn its Intensity value up to 30. You’ll now notice that its lighting contribution is considerably brighter.
The lighting using the Overhead.IES file in the VRayLightIES
Swap the Overhead.IES file out for a pear-shaped IES light by clicking on the VRayLightIES node and then browsing for pear.IES. You should be able to see the difference in the light shape in the render.
Lighting using pear.IES file in the VRayLightIES
6) Adding a VRayLightMesh
Let’s check out the VRayLightMesh next. This allows any mesh to be used as a light source within the Nuke script. Add a VRayLightMesh node into the Nuke script and connect it to the Lights scene. Add a Cube node (which we will use as geometry for the VRayLightMesh) and connect this to the mesh input of the VRayLightMesh node.
Final Scene layout of the Nuke script
Move the VRayLightMesh up on the Y axis in the 3D view, and move it to one side on the X axis. Now once again the scale is too small for the large scene scale, so change the uniform scale under the Axis tab to 500. Connect the tex input of the VRayLightMesh to the Road_A.HDR that we have been using so far in all the QuickStart videos. You can now see that the VRayLightMesh is both illuminating the render and also is visible in the render. Go to the main properties for the VRayLightMesh and enable the Invisible option. You will no longer be able to see the VRayLightMesh within the renders, even though it is still lighting the scene.
The VRayLightMesh visible in the render prior to setting it to Invisible
Disable the Invisible checkbox and drop the light’s Intensity down to 1. You will now be able to see the Road_A.HDR texture on the Cube that we are using as the mesh and how the colors in that HDR are contributing to the lighting from the VRayLightMesh. If you change its Intensity to 30 once more and drop the exposure in the viewer down to 0.05, you will see that the texture is still being used even when the light is turned up considerably.
Return the viewer to normal once again and enable the Invisible checkbox.
With viewport exposure turned down, light from texture on the mesh is visible
The Cube we are using as the mesh input for this light could be moved around or even animated. If you have an animated mesh object in your scene, you could have that object produce light within the render.
Final render with all lights active
Turn on all the lights in the Nuke script back on by selecting each light, then hovering over them pressing the D key. With all the lights active, you can see the final lighting scheme we have produced.
In this tutorial, we have covered all the different light types that come with V-Ray for Nuke and how you can use them to light a scene.
