This page provides information on the View Specific option.
The View Specific option is a mode that can be enabled from the corresponding button of the V-Ray toolbar. This mode allows modifying those V-Ray parameters that affect the lighting, mood, and composition only within the current view context.
Thus, multiple views of the same Revit project can be rendered under different lighting conditions without the need of sharing external settings files.
It also allows switching between the global light setup (which is shared across all views) and the local (view-specific) one for the same view. This is useful in cases where the same view needs to be rendered prompting different mood, for example under day and night conditions, composed vertically or horizontally, etc.
When View Specific mode is enabled, a blue dot indicator appears next to those settings that are specific for the rendered view.
Views that already have their own settings have a blue indicator in the View Selector list, whereas those that are using the global/project settings have a grey one.
Only after the View Specific mode is enabled and a view specific setting is changed, the indicator turns blue and a view specific value is created. Otherwise, the view inherits the project settings.
Right-click on any view, displays Delete view settings option. It deletes the view specific project settings from the view. Note that the indicator in the View Selector remains blue, if the View Specific mode is only turned off and not deleted from the view.
If Resolution is the only view-specific setting different from the project settings and its aspect ratio is set to Crop Region, the View Selector indicator remains gray. This is because the resolution width/height are different for each view when the aspect ratio is set to Crop Region.
View Specific Settings
Materials, geometries, render quality and general settings, such as render and GI engines, work globally and are not view specific settings.
Background Image
Camera
Fog
Dome Light
Sun
Aerial Perspective
Artificial Lights
Resolution
Background Type
Camera Mode
Environment Fog Enabled
Dome Light Intensity
Sun Intensity
VolumeAerialPerspective Enabled
Use Artificial Lights
Resolution Aspect Ratio
Revit Background Brightness
Stereo
Environment Fog Color
Dome Light Color
Sun Size
Affect Environment
Enabled
Resolution Width
Background Intensity
Stereo Layout
Environment Fog Emission Color
Use Dome Light Image
Visible Sun
Atmospheric Height
Intensity
Resolution Height
Background Color
Target EV
Environment Fog Emission Multiplier
Dome Light Image Path
Sun Filter Color
View Distance
Filter Color
Use Background Image
White Balance
Environment Fog Height
Dome Light Rotation H
Ground Albedo Color
Inscatter Multiplier
Override Emissive
Background Image Path
Auto Exposure
Environment Fog Distance
Dome Light Rotation V
Ground Albedo Blend Angle
Background Rotation H/V
Auto WhiteBalance
Environment Fog Use Artificial Lights
Dome Light HDR Flip Horizontal
Ground Albedo Horizon Offset
Background Image Flip Horizontal/Vertical
Focus Source
Environment Fog Affect Background
Dome Light HDR Flip Vertical
Background Placement
Focus Distance
Environment Fog Affect GI
Background Offset X/Y
Defocus
Background Scale X/Y
Vignette
