This page provides information about the Texture Placement UV Channel Component in V-Ray for Grasshopper.
The Texture Placement UV Channel component is used as an UVW input of a Bitmap or Gradient texture component to control the texture placement in object's UV space.
Input Parameters
Channel (Integer) – Specifies the index of the mapping channel data to use. A value of 1 takes the first available channel.
Repeat (Vector) Determines how many times the texture is repeated in the 0 to 1 square.
Offset (Vector) Controls the texture offset in the U and V direction.
Rotation (Number) Rotates the texture (in degrees).
Tile (Boolean) Specifies whether the texture is tiled along the U and V axes.
Mirror (Boolean) Specified whether the texture is mirror-wrapped along the U and V axes.
Output Parameters
UVW (Generic Data) – Texture placement in object's UVW space. The output is connected to the UVW Placement input of a V-Ray Bitmap or V-Ray Gradient component.
Example:
Download the GH definition here.
UVW Placement: Rotation = 0
UVW Placement: Rotation = 45
Rotation:0
Rotation:45
