This page provides information on the supported features of V-Ray Vision.
How V-Ray and Vision differ?
To understand better Vision's strengths and limitations, let's first see how V-Ray renderer and Vision differ. The technology used in Vision (rasterization) is fast but limited in quality and in the number of effects that can be supported. Vision's primary goal is to give you a real-time experience keeping a high framerate.
Vision is in active development, so the supported features are subject to change.
Most of the common material parameters used in V-Ray are supported in Vision. Some are still unsupported and thus see some differences in the way surfaces appear.
Vision is also still not capable of evaluating the global illumination in the scene. As a result closed interior spaces would be illuminated incorrectly in most cases. Calculating many light bounces is required for better results.
Read more about Vision at the V-Ray Vision page.
Supported Features
Main Render Features
V-Ray Feature
Vision Support
Interactive (real-time) rendering
(tick)
Live Link locally/remote
(tick)
Viewport rendering
Distributed rendering 1
(minus)
Camera
V-Ray FeatureVision Support
Ortho/Parallel projection(tick)
2-point perspective projection(tick)
VR projectionExport only
EV and auto-EV(tick)
White Balance(tick)
Depth of Field(tick)
Stereo
Auto White Balance
Bokeh
Vignetting
Vertical lens tilt
(minus)
Options
V-Ray Feature
Vision Support
Quality presetsShadow quality;
Cosmos assets
Image (AA) filtering
Temporal Anti-aliasing
Post-effect color corrections
(VFB)
ACES Tonemapping;
Exposure;
Contrast;
Saturation;
Temperature;
Tint
Global Switches(Displacement, Lights, Hidden lights, Shadows)
(tick)
File formats
PARTIAL
(png, jpg, tga, exr only)
VR formatsVR Spherical, Cubemap
Stereo output
(minus)
Environment background
projection types
PARTIAL
(Spherical only)
GI
Color mapping
(minus)
Denoiser(minus)
(temporal AA used instead)
Render Elements(minus)
Materials
V-Ray Feature
Vision Support
Generic(tick)
Emissive(tick)
Multi Material(tick)
Hair
VRscan
Bump
Outline Override
Wrapper
(minus)
Two-SidedPARTIAL
(Only front color/map slot is displayed,
translucency is currently not supported)
Car PaintPARTIAL
( Except Flakes )
Subsurface ScatteringPARTIAL
(Only subsurface color/map slot is displayed)
BlendPARTIAL
(Except: Blend color, Blend Texture Multiplier;
Additive Mode cannot be disabled)
OverridePARTIAL
(Only base color/map slot is displayed)
Material Properties
Diffuse(tick)
Reflection Color(tick)
Reflection Glossiness(tick)
Fresnel(tick)
Reflection IOR(tick)
Metalness(tick)
Surface Control(tick)
Refraction Color(tick)
Fog Multiplier(tick)
RefractionGlossiness(tick)
Multipliers(tick)
Binding(tick)
Diffuse Roughness
Fog Color
IOR
Sheen
Opacity
Bump
(minus)
CoatPARTIAL
(Only Coat Amount Color Toggle and Map slot is supported)
Textures
Bitmap
Color Space
(tick)
Color Manipulation
(tick)
Crop/Place
(tick)
Filter
(tick)
UV Noise
(tick)
Texture Placement
PARTIAL
(except: 2D (UV Channel): UV Channel/Set, Tile UV cannot be disabled; except: Environment)
V-Ray FeatureVision SupportNotes
Color(tick)
Temperature(tick)
Gradient(tick)
Sky PARTIALOnly Custom Orientation, Intensity Multiplier and Clouds (except Ground Shadows and Dynamic Clouds) are supported.
Color Correction (tick)
Spline Curve (tick)
Bezier Curve (tick)
Simple Mix3 (tick)
Mix (Value)3(tick)
Mix (Operator)3(tick)
Mix (Map)3(tick)
Multi-SubPARTIALOnly: Random by Render ID, Random by Instance ID
TriPlanar
PARTIAL
Except: Texture Transforms, Randomization
Mode is One Texture only
Checker(tick)
Grid(tick)
Tiles(tick)
Cloth(tick)
Leather(tick)
Bulge(tick)
Water(tick)
Noise A(tick)
Noise B(tick)
Cellular(tick)
Marble(tick)
Splat(tick)
Smoke(tick)
Stucco(tick)
Rock(tick)
Granite(tick)
Speckle(tick)
UVW PlacementPARTIAL
Except: 2D: UV Channel/Set and Tile UV; except: 3D and Environment;
UVW(minus)
Ray-Traced Textures(minus)
Edges, Falloff, Fresnel, Dirt, Curvature, Distance are not supported.
Lights
V-Ray Feature
Vision Support
SunPARTIAL
Directional Light
PARTIAL
(Except: Affect Atmospherics;
Affect Diffuse and Affect Specular are always enabled)
Dome Light
PARTIAL
(Except: Decay, Caustic Photons)
Mesh Light(tick)
Omni Light
PARTIAL
(Except: Shadow Radius)
Point Light
PARTIAL
Spot Light
PARTIAL
(Except: Decay, Caustic Photons, Shadow Radius)
Sphere Light
PARTIAL
Rectangle Light  PARTIAL
(Except: Directionality, Caustic Photons)
IES LightPARTIAL
(Except: Diameter, Caustic Photons;
Shape only from IES file, Affect Diffuse and
Geometry
Proxy mesh(tick)
Cosmos assets(tick)
Infinite plane (tick)
V-Ray Instancer(tick)
V-Ray Scatter(tick)
Proxy scene
PARTIAL
(Except : Lights)
Section Clipper
PARTIAL
(Except: Materials, Affect Lights,
Camera Rays only, Affect Light Geometry)
Fur 2
PARTIAL
(Length and Material only)
Decal
PARTIAL
(Except: Z Order, Normal Angle, Fade Out,
Fade Out Angle and Backside Projection)
V-Ray Mesh Clipper
Displacement
(minus)
Other
Material Override(tick)
Aerial Perspective
PARTIAL
(Except: Affect Environment;
Affect Background cannot be disabled)
Environment fog
PARTIAL
(Except: Emission, Scatter GI, Affect Secondary rays;
Affect Camera rays and Affect Background cannot be disabled)
Outlines(minus)
Cloud animation(tick)
1. – By default, Vision is a lightweight viewer, so distributing the scene load is mostly unnecessary. Instead, Vision offers support for Live Link. This allows loading a heavy scene to V-Ray in one machine and streaming the view with Vision launched on another.
2. – For Fur to appear in Vision, the keyword "Grass" should be added to its name. Fur is only applied to the top surface of the object (+Z axis). A diffuse texture, used in a material applied to the fur (or its host object), will be downscaled to allow a smoother color variation between the individual tufts of grass.
3. – In V-Ray 7, the Simple Mix, Mix (Value), Mix (Operator) and Mix (Map) textures are deprecated. They are replaced by the Layered texture.
  • Sun and camera animations from Grasshopper can be rendered in V-Ray Vision both through Live Link or from manually exported .vrscene files. Note that object animations are currently unsupported.
