This page provides details to using the post rendering tools for adjusting image colors and contrast.
Floatingpagetoc |
The V-Ray frame buffer allows various color corrections to be applied to the image. Some of the corrections are applied only when the image is displayed on the screen, but are not applied when the image is saved to disk. Corrections that are not applied for disk images are those that are only required to display the image. Some of the corrections are applied only when the image is displayed on the screen, but are not applied when the image is saved to disk. Corrections that are not applied for disk images are those that are only required to display the image - i.e. sRGB, LUT, OCIO, ICC color corrections. Corrections are generally applied as they are listed in the color corrections window from top to bottom - i.e. exposure is applied first and display color corrections like LUT, OCIO and ICC are applied last.
You can turn on and off a particular color correction using the check box to the left of its name. You can expand and hide the parameters for a particular color correction using the button. Clicking on the button displays a short menu that allow you to reset the parameters for the particular color correction to their default values, and to save and load just the parameters for that color correction.
UI Text Box | ||
The Color Corrections panel can be docked or undocked from the VFB by right-clicking the Show corrections control button. |
Global Presets
Section | |||||||||||||||||
Exposure
White Balance
Hue/Saturation
Color Balance
Levels
Curve
Section | ||||||||||||||||||
Section | ||||||||||||||||||||||||||||||||||||||||||
Background Image
LUT
OpenColorIO (OCIO)
ICC
