NameDescription
corona.iscoronaexrEquals to 1 when the file is saved in the CXR format.
Prefixed bycorona.cmParameters for tone mapping, LightMix and used LUT.
Prefixed by corona.bgParameters forBloom and Glare.
Prefixed by corona.curvesStore used curve parameters.
Prefixed by corona.denoiseParameters for Corona Denoising.
Prefixed by corona.sharpSharpening parameters.
Prefixed by corona.blurBlurring parameters.
Prefixed by corona.vignetteParameters required to apply vignetting.
Prefixed by corona.renderstampStore text of file-save-time render stamp and other related settings.
corona.elementsOrdered list of render element definitions. Each element definition consists of the element's name, type, and list of flags further describing the element's features and how the element should be interpreted with regard to tone mapping, bloom and glare, etc.
corona.stats.passesTotal number of computed passes.
corona.stats.timeTotal time measured in milliseconds elapsed since render start.
corona.stats.raysPerSecondAverage number of rays computed per second measured since render start.
corona.stats.raysPerSampleNumber of rays needed to compute one taken sample.
