Name | Description |
corona.iscoronaexr | Equals to 1 when the file is saved in the CXR format. |
Prefixed bycorona.cm | Parameters fortone mapping, LightMix and used LUT. |
Prefixed by corona.bg | Parameters for Bloom Bloom and Glare. |
Prefixed by corona.curves | Store used curve parameters. |
Prefixed by corona.denoise | Parameters for Corona Denoising. |
Prefixed by corona.sharp | Sharpening parameters. |
Prefixed by corona.blur | Blurring parameters. |
Prefixed by corona.vignette | Parameters required to apply vignetting. |
Prefixed by corona.renderstamp | Store text of file-save-time render stamp and other related settings. |
corona.elements | Ordered list of render element definitions. Each element definition consists of the element's name, type, and list of flags further describing the element's features and how the element should be interpreted with regard to tone mapping, bloom and glare, etc. |
corona.stats.passes | Total number of computed passes. |
corona.stats.time | Total time measured in milliseconds elapsed since render start. |
corona.stats.raysPerSecond | Average number of rays computed per second measured since render start. |
corona.stats.raysPerSample | Number of rays needed to compute one taken sample. |
