This page provides information on the V-Ray Temperature Color Map.
Section | ||||||||||||||||||||||
Basic Parameters
Common Uses
In each example below, the sphere lights have the same VRayLightMt applied to them. A VRayTemperature texture map is applied to the VRayLightMtl to show various color temperatures between each example image. The VRayTemperature has Color mode set to Temperature.
In the final image below, five separate VRayTemperature texture maps were used, each with a different color temperature to show a variation. No other changes were made to the VRayLightMt.
Section | |||||||||||||||||||||||
