Color mode – Specifies the mode in which the color is determined: Color – The color is directly specified by the Color parameter. Temperature – The color temperature (in Kelvin) is specified by the Temperature parameter. Red – Specifies the value for the Red channel. Note that the full intensity is reached at 1.0 for this parameter (and not 255). Green – Specifies the value for the Green channel. Note that the full intensity is reached at 1.0 for this parameter (and not 255). Blue – Specifies the value for the Blue channel. Note that the full intensity is reached at 1.0 for this parameter (and not 255). RGB multiplier – Specifies a multiplier for the color strength. Alpha – Specifies the value for the Alpha channel. Note that the full intensity is reached at 1.0 for this parameter (and not 255). Color – This color swatch can be used to visualize the resulting color. It can also be double-clicked to bring up the standard Maya color chooser. Gamma – Specifies a gamma correction applied during rendering. This does not affect the Color swatch. |
